automatic flywheel/ flexplate
on a fe enigne does it matter which transmission you use as to whihc flexplate? in other words are all the fe flexplates for 352 360 and 390 all the same for any ford automatic transmission? such as mx and c6. can either trans be used with any flexplate for these three engines?
Hawkrod
Re: automatic flywheel/ flexplate
Post by Hawkrod »
Yes, the COM and the C6 use the same flywheel. there are two different ones though. Ford changed the starters and flywheels in 65 so the older flywheels won't work with the newer starters unless you have a custom drive (yes they are available). You can put a newer flywheel in a 64 and older car and the newer starter will bolt right on and work fine. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
so would a tooth count be the easiest way to determine which ones a person had and was going to use? i have what i think is a 67 352 a 72 360 a 71 390 and a 70 360. i am hoping that the 67 352 with a contorvesial transmission would be able to be swapped to a 360 or 390 of the newer years of trucks 67-75 or 6 when ever the fe stopped being made..
Hawkrod
Post by Hawkrod »
Yup, the tooth count is the only difference. The fact that it is a 67 means the flywheel is the same as a 65-76 and will fit 352, 360, 390 and 427. BTW brand new ones are about $40. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
