Quick question...How is the fuel filler pipe supposed to sit according to the cab and the rubber grommet? I'm not sure how exactly it goes together, does anyone have pics up close to how it should look, this is for the in cab tank by the way. I finally got all new hardware for the tank and went to put it back together and forgot how it should look...
Thanks-390
Fuel filler pipe
- 390F100
Fuel filler pipe
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- Dragon
Re: Fuel filler pipe
I hope this helps
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
- sideoilerfe
Here's an actual picture.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
the outer gromet slips over the tube. and then fits on like the above pic. the outer groumet fits in the hole in the cab.
