instrument cluster question
shortbedCUSTOM
Post by shortbedCUSTOM »
ok, I ran over to the salvage yard and came across an almost perfect, save some minor discoloration, instrument cluster with the oil press. and volt guages. no IDIOT lights. :D
my question is, will it swap right in place of my '70 model cluster with idiot lights WITHOUT wire modifications???
please advise.
FORDification
Site & Forum Admin
Site & Forum Admin
re: instrument cluster question
Post by FORDification »
No, it will not....you'll have to do a little rewiring to make it work. The main wiring harness on idiot-light trucks aren't set up to use an ammeter. The feed to the ammeter comes off a shunt from the solenoid-to-alternator cable.
shortbedCUSTOM
any tutorials on how to make them work?
prostreetjim
Post by prostreetjim »
FYI, you may already know, I learned after I purchaced my replacement cluster, only a 70 will work, the plug on the 70 is shorter than on 71-2 models
jor
Post by jor »
customcrewcab
Post by customcrewcab »
hey jor
i gave those parts to your daughter. the plug for the gauges you might get if they guy coming by this weekend does not want it. he ask first.
FORDification
Site & Forum Admin
Site & Forum Admin
Read the discussion threads on the shunt:
http://fordification.com/forum/viewtopic.php?t=2094
http://fordification.com/forum/viewtopic.php?t=902
I haven't personally done the mods yet to hook up a shunt to make the factory ammeter work, so I can't help you out further yet.
