Does anyone know..
goodtimejonny
Does anyone know..
Post by goodtimejonny »
What the biggest motor you can cram into a 68 F100 is? It has the 360 in it currently.
Just curious.
Thanks
1968 F100 Short bed Bump
Dragon
Re: Does anyone know..
Post by Dragon »
Any Ford Truck engine or car engine will go in them.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
are we linited to older ford engines or can we go out on the modify the inner fenders and frame binge? how about a 4 1/4 over the road cat engine? it will fit with a few mods.
fastEdsel
Post by fastEdsel »
428 is as big as I ever went. I suppose the Cat engine might be alright but don't know how it would handle with a tandem steering axle on the front end! :hmm:
fmartin_gila1
Post by fmartin_gila1 »
You could go to a 534, but it was physically a very large engine and heavy.
Fred
How much money do you have?
:wink:
As has been said any gasoline powered ford car or truck engine will fit with varing degrees of dificulty. All the older stuff (FE's, Windsors, Clevelands, Limas) is just a matter of finding the right combination of parts.
FORD428CJ
Post by FORD428CJ »
goodtimejonny wrote:What the biggest motor you can cram into a 68 F100 is? It has the 360 in it currently.
Just curious.
Thanks
Seen an SOHC 427 squeezed into one! WOW was that cool. I'll have to find the pix on line, if I can.
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
71 LONG BED
Post by 71 LONG BED »
FORD428CJ wrote:Seen an SOHC 427 squeezed into one! WOW was that cool. I'll have to find the pix on line, if I can.
Check out this post!
John Member #1549
Image Image Image
Dragon
Post by Dragon »
That is an easy stuff the engine in trick. The SOHC is the same width as any FE at the block mounting area. The Heads overhang the block but F series truck have plenty of room on the sides for clearing a FE and more that enough room on the front for the chain case.
I drove a SOHC 54 F1 with top loader and that was a really tight fit.
Try stuffing a SOHC into a 67 Mustang it fits but if not for the top plugs you would never tune the engine.
Old Fords Rule
My Gallery
Spark test
