351W swap?
351W swap?
I have an '86 351W completly rebuilt and my original project is no more. How tough would it be to drop this in a '69 with a T18? Truck now has a 300 six. I can't seem to find out about 351's and 4 speeds. I would rather keep the six but it needs a rebuild and I have this motor just sitting.
- fomocoguy
Re: 351W swap?
The 351W and 302 are nearly identical, with the only differance being that the 351W has a taller block, so you will have issues finding headers that fit if you were going to use them. There were plenty of four speeds behind 302's, but I believe the two engines are balanced different, so you may have to put some research into a proper flywheel to put behind the 351. You may have to get a 302 flywheel rebalanced, but I'm sure that if there is a flywheel out there that will work somebody here will know what you need to be looking for. As for the engine all you will need is a set of 302 engine stands and motor mounts to bolt it in.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- SteveC
Re: 351W swap?
dont quote me but the older 302 and the newer 302 have a different flywheel the older 302 and the 351 are the same as far as flywheel.
Like i said dont quote me but im pretty sure im right
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Re: 351W swap?
the bellhousin gblot patterns are the same for 240 300 302 351w and c i think. the 351m is the same bolt pattern as a 429 and 460. the 352 360 390 427 and 428 are in a bolt pattern by themselves also. if your swapping transmissions too. you may need a different length driveshaft. besides the engine perches which have already been mentioned.
- theskytoucher
Re: 351W swap?
all you should need are 302 engine stands stock 351w engine mounts and a set of exhaust manifolds or headers (302 headers will work but they are very very tight) then drop it in and have fun!!! transmission wont need to move and wat ever flywheel you had for the motor before will work!!! the spline on the t 18 should be 1 1/16 X 10 so any clutch with that will work!!! hope this helps!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
