Motor Mount help?
shaggy!
Motor Mount help?
Post by shaggy! »
i have a 1980 F-250 4x4 and i have pulled the inline 6 with a 4 speed tranny that was in it. and i am replacing it with a 351m with a c6 tranny but the motor mounts on the 351m sit to low to bolt to the frame the oil pan hits the crossmember. was wondering about what motor mounts i am supposed to use or any other helpfull suggestions.? thank you!
FORD428CJ
Re: Motor Mount help?
Post by FORD428CJ »
shaggy! wrote:i have a 1980 F-250 4x4 and i have pulled the inline 6 with a 4 speed tranny that was in it. and i am replacing it with a 351m with a c6 tranny but the motor mounts on the 351m sit to low to bolt to the frame the oil pan hits the crossmember. was wondering about what motor mounts i am supposed to use or any other helpfull suggestions.? thank you!
Just asking but are you using a front sump oil pan and not a rear??? Just needed a little more detail is all..... :thup:
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
