bad timing chain
aramil
bad timing chain
Post by aramil »
can i just replace the gears or should i get the entire timing set? what is a good brand and what type should i look at for a stock 360.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
Dragon
Re: bad timing chain
Post by Dragon »
The whole set never just part. Ford dropped that partial change policy long before I went to work with them
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
yea if its not the plastic gear that goes bed. its usually the chain has streched out if it has metal gears.
fastEdsel
Post by fastEdsel »
I installed a "double roller" timing chain on a couple of my FE's. They run great and I have never had one stretch. But yes, replace the whole set. :thup: :fr:
fitzwell
Post by fitzwell »
3 piece set from Napa. Double rollers work well also. Soak the chain overnight in oil before you install it. Helps prevent dry start.
FORD428CJ
Post by FORD428CJ »
fitzwell wrote:3 piece set from Napa. Double rollers work well also. Soak the chain overnight in oil before you install it. Helps prevent dry start.
I never soak my chains over night. Maybe a little pre-oil. Never had problems, even with roller motors. JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
Dragon
Post by Dragon »
Same here pour some oil and go. I never installed a roller chain that was dry from factory the chains always have some lubricant in the rollers. Now on high spring pressure race motors the chain is oiled and the motor turned slowly by hand a few revolutions to get the lifter, cam and chain coated in oil.
Old Fords Rule
My Gallery
Spark test
FORD428CJ
Post by FORD428CJ »
Dragon wrote:Same here pour some oil and go. I never installed a roller chain that was dry from factory the chains always have some lubricant in the rollers. Now on high spring pressure race motors the chain is oiled and the motor turned slowly by hand a few revolutions to get the lifter, cam and chain coated in oil.
Pre-lube the system in that case. Instead of rotating the engine by hand, you can prime it with a drill. Works better and you know everything is well lubed ready to go. And if you are an all out Drag car......Then a Accumulator would be choice. Prime on the spot before ever start! JMHO
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
aramil
Post by aramil »
i was just wondering about buying the part since napa has them by part and as a set, but jegs has a roller set for $23 that i might try out since the price seems right. this will be my first time doing anything on a motor except for water pumps and head gaskets. thanks for the help guys :fr:
willowbilly3
Post by willowbilly3 »
Do the whole set, they're inexpensive. I wouldn't worry about buying real good ones. A $23 NAPA set will probably outlast your engine if it has already wore out one set.
Dragon
Post by Dragon »
I am not into chinese made 23 dollar anything. My stopping point on roller chains is 43.
Old Fords Rule
My Gallery
Spark test
me chinese me play joke me go we we in your coke. and your truck too.
aramil
Post by aramil »
my engine is going to last alot longer than my truck so i want somthing good, is cloyes a good brand? its not the roller i was looking at, but it seems decent and will get me by.
aramil
Post by aramil »
so im taking that cloyes is a good brand but sellers use junky gears and the good chains?
aramil
Post by aramil »
cool thanks dragon, you have been really informative.
