High torque starters: Powermaster, RobbMc, and NPD.
robroy
Post by robroy »
Good evening,
I see in the NPD catalog both standard rebuilt starters and these special, "high torque" starters.
They're a little more cash: $100 versus $75.
1. Would installing this starter be a smart move if it's going to be used on a 10:1 FE? Or would the stock starter handle the high compression engine with no problem at all?
2. Is a starter with increased torque a risky idea--could it grind up the flywheel or put an undue electrical load on the circuit?
What are your thoughts on this starter?
Thanks!
-Robroy
willowbilly3
Re: Are NPD high torque starters a good idea?
Post by willowbilly3 »
I doubt if the extra torque would pose any problems. You might want to look into the compact, permanent magnet type starters. I used one on a 300 and it was the best. They are probably a little more money but might cure some of the header clearance issues.
robroy
Post by robroy »
Hey WillowBilly3,
Thanks for the suggestion! Those look interesting. You're referring to the starters like the Powermaster mini starters on Summitracing.com, correct?
I'll have to study the advantages of these starters over traditional units.
Thanks again!
-Robroy
robroy
Post by robroy »
Hey WillowBilly, I checked out http://www.powermastermotorsports.com/1 ... rters.html and these look really interesting!
One of the main points they're advertising is, "No heat soak problems."
What are heat soak problems? Are traditional starters in some way damaged by ambient heat?
Thanks!
-Robroy
robroy
Post by robroy »
I called Powermaster and asked about their starters; they said that they're all made in the USA. On their web site it makes that claim only for their top model unit, the UltraTorque. I did hear that they use several small parts that are imported though, but all the large parts are domestic and it's put together here.
These seem like pretty good deals, but I don't have a complete understanding about the problems they're designed to solve. The obvious ones are form factor (being small), weight, and increased torque. I'm not sure about the heat soak issue or what "five position indexing" means.
Thanks!
-Robroy
I have a powermaster master torque on mine.
Being much smaller than OEM there is a larger air gap particularly with headers.
I can actually get it in and out without removing the header If I'm careful (you won't do that with a stock one, the header and starter has to go in as a pair...
robroy
Post by robroy »
Hey Robert! Okay, knowing that the stock starter tangles with the header that much makes the sale for me. I wouldn't want to bury my ten year old starter under the header, even if it seems to work fine at the moment!
How does that starter sound, compared to the stock starter?
Thanks Robert!
-Robroy
willowbilly3
On the 300 it had a bit of a whine that you don't hear on an old style. Mine was a stock Ford unit. I think the 5 position indexing must mean it has 5 different ways it can bolt on. Most headers run REAL close to the starter and tend to cook them at a fairly rapid pace for some owners. The only FE I ever had headers on was a highboy and they didn't have that issue because the front 2 pipes went around the cross member so the header went on in 2 pieces and slid together.
robroy wrote: How does that starter sound, compared to the stock starter?
-Robroy
Whine is a good description, it doesn't sound like an old dodge, but does have a different tone. Mine fires off pretty fast so its not so noticeable.
Ranchero50
Post by Ranchero50 »
Yeah, for the money a mini is a very good investment. Much more torque, much quicker start. Mush less heat soak issues.
Jamie
robroy
Post by robroy »
Hey WillowBilly3, Robert and Jamie,
Thanks for the sound descriptions! It sounds interesting.
I'm definitely going to pick up one of these MasterTorques.
Thanks again!
-Robroy
1971ford
Post by 1971ford »
those sound awesome, me wants :drool:
i couldnt find it on there site, how much do they go for about? im guessing alot of $$$$$, but they sound worth it.
-Ryan
robroy
Post by robroy »
Hey Ryan!
The model Robert has (and I will have in the near future) is $189 at Summit. This price seems great to me, since a stock, rebuilt starter is $89, and these are new (not rebuilt).
http://store.summitracing.com/partdetai ... ew=sku&Ns=
-Robroy
willowbilly3
Just a side note on Ford starters for some of you younger readers. They really hate a weak battery and repeated attempts to start a Ford with a weak battery will smoke your starter.
robroy
Post by robroy »
Good morning WillowBilly3, I've never heard of weak batteries smoking starters! Interesting. Is this true only for the stock starters? Or is it also true for these fancy modern starters?
Thanks!
-Robroy
