67 F-250 2wd frame up restormod 6-9(Warning!)Large pics!
Re: 67 F-250 2wd frame up restoration
Dadgum that truck is CLEAN, Good luck on your project,I olny did a cab swap and it wore me out.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
wow.. this is exactly what I am going to do...
Looks like a pretty good base to start with. I look forward to seeing your progress.
- fireguywtc
Got the truck down to bare frame. Got everything off except all the suspension and brake lines.
Cab coming off. It needs the most work, but I was glad to find out when I took all the glass out all the frame under the gaskets still look as good as from the factory!
The bare frame.
The sticker thats been on the truck since I have owned it. (it's for the anti logger hippies). BTW if anyone can get me some more of those stickers please contact me
The bare frame.
Bill
- fireguywtc
Got the frame painted today with the help of my wife. Used por 15 and it went on nice. A lot of sweat equity went into the prep of the frame so I am glad that is done! Next goal is to get all the suspension painted and put back on so I can have a rolling chassis again. When it is all prepared I will move it outside and cover it for storage to free up room to work on the body in the garage.
Bill
Damn looking good!!!
- 69twotone
Wow, You are moving along quickly. Did you use the cherry picker to lift your cab off?
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- fireguywtc
Yup that is how I got the cab off with a little muscle help. For the time being that is all it is being used for is to move the cab.69twotone wrote:Wow, You are moving along quickly. Did you use the cherry picker to lift your cab off?
Bill
Man, all these people with beautiful frames!
- PhilthyF100
at the speed you're going you'll have it done in no time
looking very good. Though the truck looked damned nice to start with
1969 F350 wrecker
1975 F100
1973 Falcon hardtop
1975 F100
1973 Falcon hardtop
- fireguywtc
Re: 67 F-250 2wd frame up restoration updated!
Just an update. Have not been getting as much work done as I would like since the holidays keep me pretty busy with other stuff going on but I do work on it when I can. I had to abandon working on the chassis for a while. Waiting on machine work and getting other hard to get parts together to finish assembly. I started working on the cab in the mean time. Started putting in the new floor pans and cut out the kick panels since they where badly rusted. The floor pans are more work then I had hoped but just setting them in there and seeing how nice they look makes it worth while. Next I will work on getting the new cab corners put on and maybe the new cab mounts as soon as I figure out how to get those on correctly Not pictured I got the floor plans temp tac welded in, this weekend I will try to do all the finish work on getting them installed.
cab floors cut out and everything cleaned up
mice nest I found in P/S kick panel. It was by far more rusted then the D/S which had no nest. I did cut the D/S out also since the insides are both rusted a lot!
holy cab corner
holy cab corner
Bill
- fireguywtc
Re: 67 F-250 2wd frame up restoration *updated!*
Got the floor pans in finally. I do have a little touching up to do, I ran out of wire on the welder. Plus doing a little touch up grinding. Please don't make fun of my amature welding, what a pain it was to spot weld all the way around those pans!
Before and after pics
Bill
- fomocoguy
Lookin good! I sure wish I had the room to to the same to my truck. It may end up in pieces in the back yard come spring...
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- fireguywtc
I don't have that much room, just a 2 car attatched garage. Just the cab and chassis is in the garage at the momement. The bed is in the back yard with the entire front end inside of it.
It's my belief that the size of a shop is like the size of a pay check. You always want a little bit more. I definetely want more!
Bill
- MadMaxetc
That cab is going to be a lot of work...but very rewarding!
Looking good!
Looking good!
Dan
FORD Girl
Photobucket Pictures
FORD Girl
