I have a 1972 F-100 and the rear lights have went out. The only lights that work are the backups. I have no rear turn lights, brake lights, flashers, or running lights.
I have checked the bulbs, fuses, sockets, and all connections.
I have been told that the turn light switch could cause this. Could this switch really cause all of this? Can I get this part at the big parts houses, or am I going to the junkyard with my steering wheel puller?
Thanks,
Milton
Rear lights.
- flyboy2610
re: Rear lights.
Welcome to the forums!
Do you have running lights and turn signals in the front, or is it just the rear lights that have gone out?
re: Rear lights.
Fronts are good, except the turn signal/flashers dont blink. That would be caused by the lack of load from the rears.
Milton
Milton
- bluef250
re: Rear lights.
I believe that all the lights circuits that blink and flash go through the turn signal switch - turn, brake, and flashers. All the other lights go through the light switch, except the backup lights. If the rear running lights are not working then you may have other problems other than the turn signal switch. Check the grounds, sockets, and bulbs again. Clean everything good and use dielectric grease when you put it back together. With the work involved, I would stay away from the wrecking yard for a switch. An aftermarket bolt in turn signal switch cost less than $50. If the turn cancel does not work, then the signal switch probably has seen better days and should be replaced. Another thing to consider is the fuse block, as the trucks get older, the fuse block has been known to fail.
re: Rear lights.
Yes, as far as I know you can still get those at the local parts house. Here's an NOS piece that's listed on E-bay:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=50459
