390 Intake question
Moderator: Ranchero50
- Comet
390 Intake question
Does anyone make a dual carb intake set up for the 390?
- bryantracing460
re: 390 Intake question
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
- DuckRyder
Blue Thunder Makes the intake.
Both DSC and Carls Ford Parts are good sources.
- DuckRyder
BTW,
DSC runs these as "Buy It Now" on EBAY occasionally with the correct Carbs, linkage, fuel log, and so on. Basically, a complete induction for less than you can put it all together for.
Beware though, the Carbs are about a grand, and regular Holleys do not work right.
If you really want a top end rush, go for a "Tunnel Wedge".
- willowbilly3
Lots of vintage ones out there too, including the ones that came on the R code 427s. Be careful if you buy a used Mickey Thompson, it requires a special longer distributor and is worthless without it.
- Comet
Cool stuff, thanks.
