I am looking for a carpet kit for my 67. I notice that some places have a different kit for "high center" cabs w/ C6 trannys. My truck has a cruisomatic (MX-HD) but I plan to put a C6 in it.
Question: Does this mean I need the "low center" carpet kit?
Question: Does this mean my C6 won't fit under a crusomatic cab?
Warm Regards.
Carpet kit/C6 question...???...
re: Carpet kit/C6 question...???...
i have a c6 and it has the high transmission hump....problem is most of the replacements i have found have the cut out for a stick shift
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
Hopefully somebody will correct me if I'm wrong, but I believe the 'low-hump' trucks are those without a bolt-on cover. Those WITH a bolt-on cover are the high-hump. I've never seen more than one height of bolt-on hump, but I could be mistaken.
- mk
From what I've seen, the low tunnel was used with just the C4 or the three speed transmission. There is only one height of bolt on tunnel cover I've seen used and those were on four speed trucks. I'm not sure if it was used to clear the C6 trans as well. I'll be paying a visit to the wreckers this weekend so maybe I'll have an answer later -unless someone with an FE/C6 combo would care to comment first.
mike
mike
- 68F250
Re: re: Carpet kit/C6 question...???...
Hi mike! BigRedTruck already did. Yes C6 had high tunnel just like 4-speed but no hole. As you said C4 and 3-speed didn't.mk wrote:-unless someone with an FE/C6 combo would care to comment first.
mike
- mk
Thanks, Barry
my post was made at one am and I just hadn't absorbed the previous post
mike
mike
- 460 crew
try giving these guys a call I got mine for the crewcab from them through another company but still around 100 bucks for 2 pieces. http://www.accmats.com/
