72 F250 4x4 Restoration
Re: 72 F250 4x4 Restoration
Getting me all excited to finish my 72 Jeep Wagoneer!!!! I need to cut out time for it. That's freaking RAD you're making time for this.
Celebration day!!!! For the first time in over 20+ years, there’s an engine under the hood of my truck!!! Thanks to my wife, my mom, my brother and SO MANY of you in this group! Still a long way to go, but progress is being made!!!!
- hdman90
Jasen,
Been following your rebuild on FB as well. You should be very proud, you've come a long ways in a short amount of time!
Keep up the good work, and we cant wait to see that shes in running order!
- Bullitt74
Great work man!
- hfdco4
Changing that grill and hood made a huge visual impact.
FE390PC
- cdnwillyg
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
It has been an absolute whirlwind of a week! Exactly a week ago I decided to go ahead and start moving the motor over into the new truck. Since then we’ve had a lot of ups and downs, we’ve had some stripped bolts, we had the adventure of getting the exhaust lined up, Miss matched headers, installing a clutch, lots of learning, lots of failing, and lots of big successes. In the end we still had to worry about a possible head gasket leak, which we still don’t know what the answer to is on that, but it looks like it might’ve just been condensation or water that got in when I was power washing it. Here are some photos of the adventure, the motors in, she starts right up! Now it’s on to the drivelines, rear diff, brakes, a seat and a steering wheel!!!
More photos! She has a hood attached!!!!
- basketcase0302
Dude...I would be sleeping in the truck after this accomplishment-congratulations!Stuntmonkee
We gotta' talk about getting you some disc brakes soon-you'll be so glad you made the small investment.
Great looking motor and very clean engine bay. This trucks going to be awesome when your done!! Congrats on getting that motor in!
Kyle
Kyle
Point me in the direction!!! What’s the rough cost?
basketcase0302 wrote:Dude...I would be sleeping in the truck after this accomplishment-congratulations!Stuntmonkee
Celebration day!!!! For the first time in over 20+ years, there’s an engine under the hood of my truck!!! Thanks to my wife, my mom, my brother and SO MANY of you in this group! Still a long way to go, but progress is being made!!!!![]()
- Manny
That's AWESOME!!! having a motor that is in a runs is massive. Proud for you not long you'll be driving around!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- basketcase0302
The easiest way to get the braking better for now will be simply to add a power MC that has a booster, (until you can find a disc brake front axle). The disc brake MC will still make a world of difference in the stopping power.
There's two options to get the disc brake master cylinder hooked up. The first is to try to find the original firewall booster brackets / booster / and master cylinder from a bump, (or dent) era donor truck. Go about half way down this page to see the differences-there are too many for me to list:
http://www.fordification.com/tech/clutc ... ackets.htm
Or like I see many folks doing-bolting up a new aftermarket brake booster and MV, (whioch usually requires making new brake lines from the combination valve, (down on the frame rail) up to the MC-which isn't all that hard once you have the double flare tool.
Try these guys to confirm if they have a new aftermarket booster MC assembly for your truck:
https://www.ebay.com/itm/1957-77-Ford-F ... mm&vxp=mtr
Wildwood is a top name for the brake booster but you'll pay double the price for their name.
- popeyes71
Congrats on all the progress! Just remember, all the road blocks that you hit are chances for you to learn and to further succeed in life. Your truck is looking good and I'm looking forward to seeing more of your progress!
-Popeye-
1971 F-250 4x4 Highboy
