1969/79 Bumpside Build
GIJoe4500
Re: 1969/79 Bumpside Build
Post by GIJoe4500 »
sargentrs wrote:
GIJoe4500 wrote:
Alstoyz wrote:So. What do you do, that has u traveling and working so long??? Or is it top secret??? :lol:
To greatly over simplify things, I am a nuclear power plant weld inspector.
So I'm assuming your performing a full penetration destructive test on your welds. Would that be per MIL spec or AWS criteria? :wink:
My line of work, is non-destructive. Liquid penetrant, magnetic particle, visual inspections, and I'm working on my ultrasonic certifications. Also have 5 1/2 years of eddy current tubing inspection experience.
AWS, SNT-TC-1A, NAVSEA, ASME Section XI, etc.
And all I do on my welds, is a quick visual inspection. I don't allow undercut, arc strikes, ***** fillets, or porosity.
Congratulations! Nice creds. I've been in metal fab for 35 years so i appreciate good skills. Can't wait to see how she turns out. :thup:
GIJoe4500
Post by GIJoe4500 »
sargentrs wrote:Congratulations! Nice creds. I've been in metal fab for 35 years so i appreciate good skills. Can't wait to see how she turns out. :thup:
I cant wait either. Especially since I'm just kinda winging it... winging everything. haha.
Its not too often you come across someone who knows what non-destructive testing actually is! Most people say.... "huh?" So I just tell them I'm a weld inspector, and leave it at that... even though its MUCH more involved than that.
GIJoe4500
Post by GIJoe4500 »
I suppose its time for an update. I recently purchased a new house, so I had to make this sucker a roller, and ASAP!
So I started slapping some tubing on for the backhalf. I didn't have time to plan, so this was all out winging it.
With a 4-link rear, its kind of important to have 4 links... so I got the upper links built and the brackets tacked into place.
After that, I proceeded on with getting the lower links built and brackets attached.
Full bump test shows that everything will EASILY clear. First thing that hits is the lower link contacting the bottom of the frame.
Next I welded on my lower airshock mounts. And man do I need some argon and solid core wire. I'm tired of running flux core.
Not insane amounts of double triangulation, but it is more than enough to keep the axle centered.
Bend up some tubes to weld on some upper airshock tabs.
And I was able to roll it out into driveway to load it onto the trailer!
GIJoe4500
Post by GIJoe4500 »
Also pretty much decided that I am going to use a manual transmission instead of a c6. I'm going to try to source a zf-5, but if I can't find one for dirt cheap, I'll just run the np435 I already have.
Anyone have any advice for mounting a hydraulic clutch setup in a 1969 F100? I already have a clutch pedal in the truck, so I'll probably use it, and modify to attach to the master cylinder.
fordguy_78
Post by fordguy_78 »
are you going to boat side it with trying to keep it that low?
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
GIJoe4500
Post by GIJoe4500 »
fordguy_78 wrote:are you going to boat side it with trying to keep it that low?
I would like to, but I'm not it a rush to do so. Other stuff is higher priority right now. Once it is running and driving, I'll evaluate and see if it is worth my time to boat side it. More than likely, it'll be a yes though.
Heirloom
Post by Heirloom »
Nice build :thup: I will have to start following more 4x builds since I'm moving East to mud country next year and will have to build one for myself...errr....farm.
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
GIJoe4500
Post by GIJoe4500 »
Heirloom wrote:Nice build :thup: I will have to start following more 4x builds since I'm moving East to mud country next year and will have to build one for myself...errr....farm.
I'm not a fan of mud. Rock crawling for me!
fordguy_78
mud just causes rust and all that cleaning :x rocks are much more fun.
Phill
78 Mustang
67 F250ish
GIJoe4500
Post by GIJoe4500 »
fordguy_78 wrote:mud just causes rust and all that cleaning :x rocks are much more fun.
I'll take some rock rash over some cleaning any day of the week.
Coupe5oh
Post by Coupe5oh »
Here's what I did, re-clocked the arm that worked the original linkage and welded a bracket on for the mustang master used. Image
-1993 Cobra #121, Black/ Grey leather
-1968 Mustang GT Fastback, Gulfstream Aqua
-1967 f100 pile of parts...
GIJoe4500
Post by GIJoe4500 »
Awesome! Thanks for the picture. I may just need to crawl up under there and see what I can find. It probably won't be too hard to work out, I will just need to make sure it has enough throw to fully engage the master cylinder. Which should be fairly easy to figure out, because I have an entire 1985 parts truck I can take measurements and parts off of.
GIJoe4500
Post by GIJoe4500 »
Looking at possibly building my own shifters for the transfer cases. I already have the cables for the shifters, just need to build the actual lever mechanism part. Anyone have any experience with this that could give some tips/tricks that were unexpected big helps? I have a few ideas, and don't see it being overly complex, but its always better to ask. Will be a triple-stick setup, so 3 shifters side by side.
fordguy_78
I cant see it being to hard. just a shaft with bronze bushings with spacers some .25 plate cut to whatever shape feels good. I just did the regular twin stick with one factory stick a spacer so it would fit on a 9/16 bolt and another shifter built out of some tube i found in my scrap bin some .25 plate and 1/2" bar stock also a few 3/8 rod ends.
I don't see it needing to be this complicated
mo simple
Phill
78 Mustang
67 F250ish
