Parting 3 bumps! Let me know what you might need.
Re: Parting 3 bumps! Let me know what you might need.
I could use a auto-steering column. how much? thanks!
partsbob67 wrote:I could use a auto-steering column. how much? thanks!
I have a couple auto columns but shipping might be pretty expensive. I'm in South Dakota.
Any good cab corner/back or floors?
I am in need of passenger side doors for a crew. Do you have any of those?
i sent a PM
JESUS LOVES YOU! everyone else thinks your a jackass!
PM's and parts sent!
Thanks to all!
Thanks to all!
Looking for metal kick panel the part that curves up right in below the front door hing
Do you have the rear view mirror? arm rest? speedo cable? please PM
Auto column to 37312?
PM me please
PM me please
Thanks to all!
Thanks to all!
How much for a 72 f100 radius arm bushing HOUSING ?
This is the housing bracket that holds the radius arm rubber bushing and fastens to the frame.
I think it is the driver side.
- mdbaker42
I'm looking for the z-bar assembly for 1969 f-100,soup to nuts. Mounting bracket to frame,to block and everything in between. All hardware is a must.
- mdbaker42
I need the z-bar assembly. Soup to nuts, frame mount, block/bellhousing mount and everything in between. including all hardware.
