1971ford wrote:Those are great shock hoops posted, I would simply pick one and copy it.
I don't want the bedcage to break the plane/top of the bed, if at all possible.
1971ford wrote:
Notice how the downtubes go inbetween the wheel wells however, unlike your drawing. Move them inside the wells, then you can move the downtube where the shock mounts back more to fix the shock angle, because your drawing's shock angle is a little bit too much.
Oh I know. It was a 30 second thing in paint.
IIRC you mentioned mounting the shocks directly to the plates, which means they will be a little more outboard than usual. Also, reading the chevy swap thread, all those guys run them spring under. Can't use tabs on the plates that way, can I? Thoughts?
1971ford wrote:
I would replicate the last one, the black truck. It is the most simple and easy to make and will still work great. It only requires two simple bends as well.
That's true, but I think it's ugly and it goes against my goals of going higher than the bed of the truck. Also, it takes up too much space considering it has to tie into the frame somehow, and If I aped that I'd have nadda for usable space. Well, some, but not a whole lot. This is confusing without knowing where EXACTLY I need the shocks to mount.
1971ford wrote:
But remember that you plan on having a spare or two, be thinking of ways to mount those
Love what you posted! good idea. I didn't plan on 2 spares but that looks easy. Can those holders be removed completely for some flat bed action?
