Post your 4X4 pictures HERE!!
Re: Post your 4X4 pictures HERE!!
Nice Highboy, Johnny. What size/brand tires are you running? Care to share any more specifics on the truck?
1969 F250 4X4
360 V8, C6 auto trans
small lift, 36x12.5x16.5 military tires
Tires are Power King 235 85 16 (radials). I haven't been able to find any online, so I'm not sure if they still make them. Truck is a 68 with the Ranger trim, 360 and a 4-speed. It's a former Oregon truck, so there's not much rust.
71 F250 4x4 Highboy. Just finishing up the interior; exterior more/less complete. Had this truck for 20 years now. Factory lime gold metallic (done in base/clear). Tires are 255/85/16's
- jdf
that's a super nice truck ............ the 71 was my favorite year I really like the 71 grilles that's what I started with was a 71 highboy but the isn't much of the original truck left now other then the title I put a 1995 1 ton 4x4 frame and axles under it and have replaced every body part there was to change but when its done it will still look like a 71 highboy but drive like a 95 model ....... anyway you got a cool truck there definitely one to be proud of
- KRob
Frankin Ford, had to throw the chains on today and still took a few more running tries to get through.
- 67fordtruck
Ok, Ill play.
Just picked up this 68, pulled from a field after sitting for about 10 years.
Used the carb and voltage regulator off the 67 crew to get it running. So far, gas, a starter and starter cable are all it needed to be running around the ranch.
The kicker is it has a factory 5 lug Dana 60, 3:54 geared posi(which worked really well!) Cab is toast and still deciding what to do with her. I have another 68 cab, just not sure if I will swap it on or not.
-1967 F-250 Crew Cab Short Bed
-1975 Jeep CJ5, Daily
- 460 crew
That looks tough!
WHITEY FORD
1970 F250
Flex pics, and yes I like picture whoring my stuff
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
78 Mustang
67 F250ish
Love it Phill, you have a build tread on Pirate or anything?
-Mike-
ECV 1849
ECV 1849
full size bronco as that's what it's chassis started life as http://fullsizebronco.com/forum/showthr ... 647&page=1 and all my pics http://www.supermotors.net/registry/24687
Phill
78 Mustang
67 F250ish
78 Mustang
67 F250ish
- Florian
Awesome stance! Love how the tires stick out, looks aggressive!
1971 Ford F100, 302cui, 3 on the tree
