68 mercury build
Re: 68 mercury build
[image]550[/image]
[image]556[/image]
Finished front end install.
Had to try the used mustang track pack wheels and tires for “ fit “
Now to lower the back.
[image]557[/image]
I made some saddles to swap the axle to the top of the springs.
I should have bought them. Lost 2 hours making them up.
Didn’t weld them yet till I have the engine and trans in to set pinion angle.
Looks like I will have to notch the frame.
Only about 4 inches to the bump stop and no load on the springs yet.
The engine parts should be done when I come back from work in two weeks.
Spring should be here too by that time so more chores to do.
Any advice on crown Vic swaps chime in. I’m sure I missed something..lollipops
- Manny
Looks good you figuring a mild c notch to make it or are your going to have to full cut out style notch to make it happen? Keep it up!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- mk
How's the project going? Looking forward to seeing more pics
More info on the mercs here...
http://www.fordification.com/forum/view ... =2&t=35331
mike
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
~Will Rogers
