1970 Ford F100 SWB
bickgibbs
Re: 1970 Ford F100 SWB
Post by bickgibbs »
hillcountryflt wrote:
bickgibbs wrote:I recommend POR 15 for the frame if you don't powdercoat. I have used it on the inner fenders, underside of the hood, the floor of the cab, underside of the cab and will paint the inside of the front fenders and the underneath side of the bed. It sprays easily and smooths itself. As long as it is not in the sun it does not have to be topcoated.
Did you apply it directly to the frame or did you use metal ready. That product just sounds like an etching primer.
I've done it both ways. I haven't really seen any issues with painting without the metal prep.
Maximus
Post by Maximus »
Sweet Project, and very clean work! keep up the updates!
1972 Ford F100 SWB Styleside 300ci I6 3OTT
1965 Mustang 289 T5 4 Weel Disc Brakes
1972 Chevy Blazer 4x4 350/350
1955 Chevy Big Window SWB Stepside
bickgibbs
Post by bickgibbs »
I'm finally back at it again. I had an accident involving my fingers and a table saw. I do still have all of my fingers so it wasn't as bad as it could be.
Now on to my update.
Powder coated and rebuilt the steering box and reinstalled it
Finished welding up the gazillion holes that the previous owner(s) had made.
bickgibbs
Post by bickgibbs »
Finally got my tie rod extenders ordered and put on. They are from DJM Suspension.
bickgibbs
Post by bickgibbs »
Finally got to do a little more work on the truck. This thing is taking forever.
Started blasting the bottom of the bed. Started to rain so I didn't get as much done as I wanted to.
Uni Moe
Post by Uni Moe »
Cool ramp. What if you made it so the two halfs could be easily pulled apart. And then put wheels under each one so you could tow them outside with the garden tractor when not in use.
bickgibbs
Post by bickgibbs »
They actually do unbolt in the middle of each section. they are heavy but can be moved on a dolly pretty easily, especially with a second person.
Texarado
Post by Texarado »
I've got same lowering kit on my 68 SB. I believe it is A drop of 3" in front and 6 in the rear. I think it sits just right.
Love that ramp idea, so much easier than jacking a blocking!
