1971ford wrote:WOW.... is that a F600 panel with the center cut out with your own sheet work? That is super slick.. I'd like to do the same.
I think that was the stock F250 panel.... heck, it's been so long I forgot what it originally looked like! Yes, I cut the center out and fitted a new .125 aluminum center section.
Hey.... I ran accross some old pics. That original cluster originally had round gauges in it! F600?
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
That hydroboost is a 91-97 F250/F350 application.... just had to rotate the bracket 180* and re-drill two of the holes. My peddle height will be about the same as it was.
You sure it's 91-97 and not superduty 99+? My 97 F-350 PSD is still vacuum boosted with an external vacuum pump (ask me how many times I've replaced the POS pump ) I know the superduty are Hydroboost but as far as I know none of the previous model years were..
Yes, I did a little part searching and it looks like actually 90-97 F350/F450. The thing with the 99+ hydroboost is that the actuating rod to the peddle is too long and you have to space out from the firewall to use.
Shayne
huh...Never heard of or seen hydro on those years F350 unless it was converted using super duty parts...
I could see it on the trucks bigger than F-350 but I'm suprised if it was factory that nobody in the PSD forums has swapped it in. The only threads I see on OBS brakes is either "how do I replace my vacuum pump" or " this is how I converted to Hydro using SD parts"
jeepermc wrote:huh...Never heard of or seen hydro on those years F350 unless it was converted using super duty parts...
Well.... now you can go over there and straighten all those PSD guys out!
Looks like I got this power steering figured out....
This pump came in a pile of parts from a craigslist buy...it is a Eaton BB type power steering unit that was rated at aproximately 2000 - 2100 psi. I was able to order a seal kit and new regulator valve to reduce the op pressure to 1500psi which should work... I talked with the guys over at PSC and they said 1600 psi to my steering box (78-79 Ford) max or the sector shaft seals will leak, so thats why I went with the 1500psi reg.
Shaft will be here next week.... these guys over at High Angle Driveline have taken that agricultural CV (which does not survive sustained high speed applications) and performed (what Jess describes as) a little (or was it major) brain surgery. The net result is improved lubrication and durability for street use!
HRDROKN wrote:Just don't want to be wasting money either.... I'm thinking that the High Angle 42 degree double cardan might be the way to go.
Here she is next to your standard 1350 series CV...
That PS pump should work fine. I have a similiar ZF version of that pump from a 98 F800 in my 89 F-350 with hydroboost and stock power box. I didn't touch the regulator at all, figured I'd see how it worked first. Never measured the pressure, but it feels a good bit more than the F350 had. No problems at all yet. In 4x4 on dry pavement with a few tons on the bed one finger can turn that wheel lock-lock.
Since the ZF pump I had use JIC connections I drilled and tapped my hydroboost for NPT and screwed in JIC nipples to run real hydraulic lines for hoses.
