1967 F-100 project
- 67nukeford
Re: 1967 F-100 project
Had to make some patches in the box floor, that's why I have the one panel I welded these panels from the top and bottom, to make sure they were strong. Had to replace one of the supports along the bottom also.
- 67nukeford
welds
- 67nukeford
front patch
- 67nukeford
another small one
- 67nukeford
shot the box in epoxy. Flipped it over, and shot the underside in epoxy, black urethane.
- 67nukeford
Oh, then shot 3M undercoat on also.
- 67nukeford
Mounted the 79 power steering box. Had to make a cut out in the crossmember to get to where the nuts would be welded on.
- 67nukeford
Mounted the box, then welded the nuts on the back. Welded the plate back on the crossmember.
- 67nukeford
Had the new doors dipped. I'll have to do some patching in them, and fill the trim holes that I won't be using.
- 67nukeford
Shot them in epoxy, then filled the belt line trim holes, and the holes for the factory mirrors, since I'm using a late model mirror. Also patched the corners.
- 67nukeford
Had to replace the bottom of the inner drivers side door, it was pretty rusted at the bottom.
- 67nukeford
Back to the box sides. I knew I was going to have to replace the flanges, to weld the box sides back on, so, got those made up and attached.
- 67nukeford
clamped and welded
- 67nukeford
The passenger side box corner was in pretty bad shape. I was able to find the NOS corner, and the NOS inner support online.
- 67nukeford
Welded some bracing inside the box before removing the cab corner.
