1969 Ford F250 Crew Cab full custom build
IML726
Re: 1969 Ford F250 Crew Cab on bagged/body dropped chassis
Post by IML726 »
Looks like the backspacing on the front wheels are too small (3") and with the current control arms there isn't enough lift for the wheels to clear the fenders. Looks like I will have to rehoop the front wheels to increase the backspacing and get longer control arms
The bed was taken off to finish welding the underside so I took some pics of the rear end.
IML726
Post by IML726 »
Access door is about done
Bed seams all welded up
IML726
Post by IML726 »
Pulled heated/ventilated seats from a 2020 Mustang.
IML726
Post by IML726 »
front bumper taking shape. It should be finished in the next couple of days. It will be welded to the phantom grille shell to become one piece. Also started installation of the LED headlights.
IML726
Post by IML726 »
Before and after modifications to the core support with some work on the intake.  Bumper is almost completely formed and welded to the grill shell.
IML726
Post by IML726 »
Dash update
IML726
Post by IML726 »
Started installation of the panoramic sunroof
[img] https://cimg0.ibsrv.net/gimg/www.ford-t ... 10.jpg/img]
Jbarnes79
Post by Jbarnes79 »
Wow! You've got some serious skills my friend
I'm curious where the sunroof was procured from.
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
IML726
Post by IML726 »
Jbarnes79 wrote: Sat Feb 03, 2024 4:18 am Wow! You've got some serious skills my friend
The work is being done by a shop. I don't have the skills to do the type of fabrication that's being done on this truck.
I bought the sunroof from a wrecking yard. I had them cut the whole roof of a Ford F150.
IML726
Re: 1969 Ford F250 Crew Cab full custom build
Post by IML726 »
Phantom grill progress
IML726
Post by IML726 »
The phantom grille is fabricated. I'm excited how it turned out.
IML726
Post by IML726 »
Test fitting some bolt on mods...
IML726
Post by IML726 »
One more piece to the puzzle. This is a rear cab section from 2014 Toyota Tundra Crewmax. I don't need the whole thing, just the roll down rear window, housing, and regulator.
