72 F250 4x4 Restoration
Stuntmonkee
Re: 72 F250 4x4 Restoration
Post by Stuntmonkee »
Ranchero50 wrote:Looks like a lot of fun. What I'd do and heartily recommend is getting it moving under it's own power with the minimum amount of effort. That way you can see what needs sorted out and also see what you want to change.
I'm not highboy informed but power brakes and steering is going to be a PITA. Body should swap over pretty easily once it's stripped. I'd even consider keeping the highboy body together while sorting out the drive train and get the bodywork done on the donor. Then swap the good body onto the good frame.
Most failed projects fall apart once the truck is in a million pieces.
This is almost exactly what I’ve decided - instead of assuming that the highboy drive train is internally garbage, I’m going to fluid swap, looks for any easy to see damage, pull on a few things to see if they are loose, then bolt it back together and run it.
Both of the bodies are straight, only the hood and front assembly from the highboy is toast. So I’ll keep that as close to original as possible.
Stuntmonkee
Got to spend some time cleaning up the Red 72 to get started on the drivetrain next week. Figured I could post some better photos : so this post is the 72 that is my core truck.
Stuntmonkee
More photos of the 72
Stuntmonkee
And then this is the 71 parts truck
Stuntmonkee
The back of the 71
cdnwillyg
Post by cdnwillyg »
Hey Stuntmonkey, where are you from because the minimal rust on the 72 is unreal especially the floors? :thup:
Stony Plain, Alberta, Canada
:drive:Willy
Manny
Post by Manny »
Man you go this!!! love this with those two you are gonna make a sweet one, and have lots of good parts left over! :thup: :eek:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Stuntmonkee
cdnwillyg wrote:Hey Stuntmonkey, where are you from because the minimal rust on the 72 is unreal especially the floors? :thup:
The 72 has spent its whole life in Reno Nevada - the blue 71 is a northern Cali Truck.
Stuntmonkee
Manny wrote:Man you go this!!! love this with those two you are gonna make a sweet one, and have lots of good parts left over! :thup: :eek:
Thanks!!!! I’ll def be looking for a home for the left over pieces, which should include a running 390 and most of good truck :)
Stuntmonkee
Double post
popeyes71
Post by popeyes71 »
Wow, both trucks are in pretty good condition! You will definitely be able to recoup some of your money from the parts that you will not need! Or even piece together a beater truck to use as a parts hauler and then sell it off at a later date. I'm looking forward to seeing your progress on the build!
-Popeye-
1971 F-250 4x4 Highboy
Stuntmonkee
Crappy news :(
I dug into the front and rear diff this AM . . . Both have rust and the initial recommendation is a complete replacement from axels in :(
Then we spun the Transfercase by hand and it growled back at us :( again
Anyhow, looks like I’m too early to need a parts truck, so I’m going to sell the 71’ to cover repairs to the drivetrain.
Anyone in Northern Nevada and want a running 71’ 2x 250? :(
hfdco4
Post by hfdco4 »
Don't jump too soon. I would replace the front axle anyways as those front drums aren't great. You have the rear axle from the 2wd to use. Find a front axle from a 1977 to 1979 F250 and you will have front discs. You can also grab a 205 transfer case from a 1973 to 1976 f250 and have another upgrade. You still need a lot of the parts from the 2wd so what you don't use trade for what you do need!
:fr: FE390PC
Stuntmonkee
hfdco4 wrote:Don't jump too soon. I would replace the front axle anyways as those front drums aren't great. You have the rear axle from the 2wd to use. Find a front axle from a 1977 to 1979 F250 and you will have front discs. You can also grab a 205 transfer case from a 1973 to 1976 f250 and have another upgrade. You still need a lot of the parts from the 2wd so what you don't use trade for what you do need!
This is great feedback! Thank you! Not sure why I didn’t think about the rear end in the other truck.
Manny
Post by Manny »
Yeah man i'm with Hfdco here 100% tried to post in here last night when the internet died. Posted in your other thread. With those two trucks you got..... Wish I was close by you heck 3-4 hardcore weekends you would be cruising with all the parts you got... :lol:
