67- SWB, CV swap, 2007 3v 4.6/ 5 sp
angryfordrabbit
Re: 67- SWB, CV swap, 2007 3v 4.6/ 5 sp
Post by angryfordrabbit »
I LIKE THE BED LINER ON THE FLOOR
Coupe5oh
Post by Coupe5oh »
Thanks, I really liked this color because it had a lot of pearl, it changes a lot in different light. I'm a silver fan though.
I'm hoping the bedliner will hold up well on the underside. It seems really tough and is harder than rhino, has a slicker finish. Should clean really easily when it's dirty. I hated to cover it up w sound deadener and eventually. :/
-1993 Cobra #121, Black/ Grey leather
-1968 Mustang GT Fastback, Gulfstream Aqua
-1967 f100 pile of parts...
flyboy71
Post by flyboy71 »
Looking good! Nice job on the CV swap.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
Broncobilly66
Post by Broncobilly66 »
I like the look of that Fat Mat. How was it to lay down?
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
Coupe5oh
Post by Coupe5oh »
Thanks. The fatmat is pretty easy to put in, and seems to stick well. I've been using the cheesy roller they sent, as well as a screwdriver handle to press it into the grooves. I doubled it up in most places.
Broncobilly66
Coupe5oh wrote:Thanks. The fatmat is pretty easy to put in, and seems to stick well. I've been using the cheesy roller they sent, as well as a screwdriver handle to press it into the grooves. I doubled it up in most places.
How much did it take to do the cab?
Did you do the doors and headliner?
'66 bronco
'68 bronco
Coupe5oh
Post by Coupe5oh »
I bought it a long time ago to use some on my mustang, I think it's 100 sq ft. I remember it cost me $125 or so at the time. There are two rolls about 18" wide. i I have done the headliner and parts of the firewall of the truck (single), and the floors double. I'm still not into the second roll. So I'll have gobs left to do the doors. I still haven't figured out if I'm gonna do any on the back wall of the cab yet.
FoPAR
Post by FoPAR »
very clean and nice, great job! color looks good on our trucks..... :maybe:
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
angryfordrabbit
do you have any more pics.
Coupe5oh
Post by Coupe5oh »
I don't have a lot more that aren't repetitive. I'll try to update when I make a little more progress. If there's something in particular you want to see I can take some.
Coupe5oh
Post by Coupe5oh »
Not a lot to report, but I have been getting a little bit accomplished. Gutted the auto steering column and filled the holes where the gear indicator and shifter were. I got the column bolted in and I'm about ready to build a steering shaft.
My wife bought me a dashpad for Christmas, so I got it put in tonight. I might be jumping the gun on that a little but I had to see how it looked.
shortstack
Post by shortstack »
Excellent work. I noticed in some of the earlier pictures, you had the rear most cross member installed, but it wasn't painted. Do you have a picture of the final set up of the fuel tank? Are you going to fill from the bed floor or reroute?
1971 f100 Custom, SWB, 302, T5
"It can't be that hard."
Coupe5oh
Post by Coupe5oh »
This is the best pic I have, and how it sits now. I'd like to move the filler somewhere other than the middle of the bed floor (just to be different), but I doubt if space will really allow for that. The top of the tank is pretty flush with the top of the frame. Have you seen any done differently? I'd be open to suggestions.
Broncobilly66
Coupe5oh wrote:[ Image ]
Looks great. I'm about to order a tank to put in the rails. Is that a 70 mustang 22 gal tank?? Thanks
'66 bronco
'68 bronco
Coupe5oh
Post by Coupe5oh »
Thanks. I'm pretty sure it's a 69 20 gallon tank. It's been so long since I bought it I forget.
