C6 owners...
BobbyFord
Re: C6 owners...
Post by BobbyFord »
iamthewreckingcrew wrote:Oh, and the trans mount is laying in a different corner so I forgot to get a picture of it. It's broken too.
Yours looks like a regular long shaft with console shift. What does the tag read?
ToughOldFord
Re: C6 owners...
Post by ToughOldFord »
ForingaMex wrote:I don't agree. The crossmember on the right will look the same as it does now if you flip it top for bottom. The 'hump' on the one on the right is centred, lines up with the mounting bolt hole. The other two are ofset. Unless my eyes are playing tricks on me. It has happened before (at least once) :-)
Jake
That's what I said, I think. :hmm:
iamthewreckingcrew
Re: C6 owners...
Post by iamthewreckingcrew »
I'm not sure where the tag is, if there is one on it. Where would it be?
And for what it's worth, it was hooked up in an 81 with column shift. Might have been rigged though. My buddy took that apart and the speedo cable out when we were pulling it. I do plan on using a floor shift in the 68 though if I can find a good shifter that I like.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
ForingaMex
Re: C6 owners...
Post by ForingaMex »
TOF wrote:That's what I said, I think.
I think we are saying the exact opposite.
This is what I said, in other words the one on the right is different than the other two.
it will be the same as the other two.
And this is what you said. If I understand correctely you're saying they are all the same. Did I understand you correct?
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
BobbyFord
Re: C6 owners...
Post by BobbyFord »
The tag should be on the intermediate servo cover on the right side.
ToughOldFord
Re: C6 owners...
Ah, I get you now. You're right, we're not saying the same thing. :wink:
Below I've circled the holes I'm talking about in yellow. I think if this member was flipped around it'd match the others. In fact the only difference I see in the three is the small lip in the center, red arrows, but that's probably due to it being in camera center.
ForingaMex
Re: C6 owners...
It doesn't matter any to me but the one on the right has a curve on both sides and the bump is right in the middle. The other two have a curve on one side and are straight on the other the hump is offset to one side. I'll leave it alone now.
-Jake
OldRedFord
Re: C6 owners...
Post by OldRedFord »
BobbyFord wrote:That's the extra long output shaft (with the funky mounts). What did that come out of? What does the trans tag on the intermediate servo read?
Tag reads as follows...
First line: PJD F7 L1
Second line: D5VP AA 084742
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
zakt
Re: C6 owners...
Post by zakt »
how long is the 2wd output shaft? I know the 4x4 came with a long output shaft also 18 1/2", curious on the length differece :D
1972 Ford F350 crewcab
BobbyFord
Re: C6 owners...
Post by BobbyFord »
Crap! yours is a '75, my link only lists to '74 :x
http://www.tpocr.com/fordtc.html
OldRedFord
Re: C6 owners...
Crap anybody else out there have resources to decode my tag?
Tim
iamthewreckingcrew
Re: C6 owners...
PJD F7 is the trans model number- basically means it's a c6.
L1 - not sure, but think it has to do with it being for a Lincoln
D5 - Year (1975)
V - Product line code -Lincoln Continental
P - Engineering - automatic transmission
Couldn't find anything on the rest. Sorry.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
OldRedFord
Re: C6 owners...
iamthewreckingcrew wrote:PJD F7 is the trans model number- basically means it's a c6.
D5 - Year (1975)
Thanks for that. :thup:
Tim
basketcase0302
Re: C6 owners...
Post by basketcase0302 »
Guys,
Sorry I didn't see this till now, the "work" thing is now kicking my butt!
I'm not sure if the mounts and crossmember are different between my '72 and say '73-'79 F-series 460, C6.
I remember Basketcase saying that the crossmembers are different.
Like Fordman said above they are different, here's my 79' dent vs. my 71' bump mounts again:
http://i240.photobucket.com/albums/ff13 ... C16062.jpg
There's a couple more pictures of the cross members in the above album. The tranny mount itself seemed like the "typical" (to me) C-6. I can't remember what my 4 speed looked like.
These guys can probably cypher the tag on it for you Tim:
http://www.network54.com/Forum/260730/
OldRedFord
Re: C6 owners...
Think that loooong C6 is going to give me weird drive shaft angles?
Tim
