hot rod flat red, before & after pic.
- ezernut9mm
Re: hot rod flat red, before & after pic.
thanks td. lady luck is such a sweet broad.
- td
yes she is!!ezernut9mm wrote:thanks td. lady luck is such a sweet broad.
o yea kapt, sorry i missed the last part of your ? in your last post about the paint, yes it is all ready flattened when you get it, thats the cool part about it you dont have to flatten each batch as you mix it up to spray it, and that keep you from having a variation in the flatness panel to panel.
- td
here's another cool one of when i was still in the paint process. the hood and the bed in complete bare metal. i had it all blasted by a freind and it was bare metal inside and out, even the uderside was bare. it and the hood stayed in my shop for nearly a month like this. you talking about nervous, if i had had one of those extreamly humid days that are so common here in the south it would have been bad for all that bare metal, it all would have to have been reblasted!
- FoMoCo
Those stealies are sweet. Nice and clean.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- wickedinhere
What size tire do you have on the front steelie?
You can pay more but you cant buy better.
- td
235 70'swickedinhere wrote:What size tire do you have on the front steelie?
Lookin' GREAT TD. Nice to see you back.
55F100
55F100
