a first step towards a paint job
4x4x4crewcab
re: a first step towards a paint job
Post by 4x4x4crewcab »
Just a quick update as of today. The trans has new 2nd syncro, 3/4 snycro,new bearings seals and gaskets--photo attached and the cab has the new DC mounts welded on + both new cab support rail extensions replaced. Now I need to get the bottom cleaned up and painted?
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
4x4x4crewcab
Here is a picture of the cab repair.
Mark
1999 Ford Windstar
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Hey, that's looking pretty good Mark!! You know, as long as you have the cab where it's at, you might as well get the bottom cleaned up and painted. ;) You'll never have it this far again, so you might as well.
morganater
Post by morganater »
and then since you are at it...
:P
HAHA!! Just playin with you guys. Great project, with great documentation I learned a ton.
edit: you have good taste in beer :lol:
94 Jeep I6 Back-up vehicle
reppin' AK
4x4x4crewcab
Very slow going but here is where I am at right now. Bottom of the cab is painted, next the door jambs, inner and outer cab corners and paint the back of the cab. Once the engine is gone thru the reassembly can begin
Mark
1999 Ford Windstar
67F250CS
Post by 67F250CS »
:clap: Looking good! Thanks for all the photos too :D
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
trukcrazy
Post by trukcrazy »
First of all, your truck is looking great. :clap: I will have some reference material when I get to start on my crew. Second, I am very jealous of everyone that gets to work on their trucks :cry: . I am dying to start on mine, but I have to wait until I am home for good. :D
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
FORDification
Site & Forum Admin
Site & Forum Admin
Yep, that truck of yours IS looking good! :thup: So are you thinking about using any kind of undercoating?
4x4x4crewcab
Thanks guys
Very little from what I have heard undercoating over time will dry and crack thus allowing moisture in behind the coating.I have found a 3M product called Rust fighter-I internal panel coating (part#051135-08892)that remains tacky.I have used this on the inside of my doors and will also use this spray on various areas on the underside like in the cab support braces and inside the new front cab supports etc. From what I have seen the bottom of the truck originally had very little protection and or coverage of any kind so I am thinking the paint+internal corrosion protection spray should be sufficient?
Plus I don't think the truck will see quite the same routine it has prior to the repairs.
Mark
1999 Ford Windstar
WindowsBreakerG4
Post by WindowsBreakerG4 »
I know this is old and i probably shouldn't bump it but i am going to. Any updates?
4x4x4crewcab
Not very much new progress to talk about. The cab corners are on and I am waiting for the engine work to be completed. Been really busy and havn't had much time to work on the truck
Thanks for asking and welcome to the site.
Mark
1999 Ford Windstar
greenbank
Post by greenbank »
For undercoating, there is a product that you can spray on under the finish color ("Flintkote"???) that is slightly flexible. It's not liable to cracking like regular undercoat yet provides a bit more protection than just paint.
1968 F250 Ranger Camper Special
-- 360, AT, PS, PB, disks
-- See Goldie
4x4x4crewcab
Thanks Greenbank I am not sure what I am going to do under there yet. I will keep it in mind.
Mark
1999 Ford Windstar
4x4x4crewcab
Some progress this weekend on the firewall.
Mark
1999 Ford Windstar
flyboy2610
Post by flyboy2610 »
Looking good! :wink:
Red Green
you'd better be right.
