PaPa's 69 F100 Explorer Coyote 10R80 swap
- Venomous duck
Re: PaPa's 69 F100 Explorer Coyote 10R80 swap
I decided to start with the passenger side first.
- Venomous duck
With the cab mount removed I decided to check the fit of the new mounts. These were purchased from AMD. I am not sure but I believe they are made by Dynacorn.
- Venomous duck
I cut out the center floor support and the floor pan.
- Venomous duck
I got a little out of order so I will go back one step and show where the cab support meets the rocker. This is another rust prone area.
- Venomous duck
After cutting out this section I test fit the floor support. Going take some work here.
Last edited by Venomous duck on Wed Feb 07, 2024 6:06 pm, edited 2 times in total.
- DuckRyder
nice work!
Following along.
Following along.
- Venomous duck
After cutting out the bad section I drilled out all the spot welds on the rocker forward of the cut section. With the rocker removed I was able to access the kick panel.
- Venomous duck
After a little trial and error I got a pretty decent fit.
- Venomous duck
After the kick panel finished I welded in the rocker back in place.
- hfdco4
Great work.
FE390PC
- Venomous duck
Thanks Paul. Robert, I missed your earlier post. I appreciate when someone takes time for words of encouragement. I will be taking some vacation time next week so I should make some progress.
- jzjames
- Venomous duck
You are right, that is a great post. I'm glad mine is not that bad. He did a really nice job.
- Venomous duck
After I got the rocker repaired it was time to move on to the cab support.
Last edited by Venomous duck on Sun Feb 11, 2024 10:10 pm, edited 1 time in total.
- Venomous duck
Next I cut it to the proper length to see how it fits.
