I am ALMOST done with metal work!!!! All i have left is a couple dents to pull on the hood, and to weld in the dentside fuel filler door. Then its time to buy filler, epoxy primer and highbuild. But first i need to make sure my money tree sprouts
I am getting some money off ebay though.
-cleaned out all bed seams
-welded up all bed seams, ground down. im going to put sealer over it, i dont like how the welds came out.
-patched door speaker hole
-patched incab tank hole
-searched and found all 5000 gallons of filler on the truck hiding dents
-pulled all dents
-screwed with grinder
-stripped and prepped firewall corners for por-15
-plugged lots of holes
-Got ANOTHER hood. This is my 3rd hood i have gotten for this project. Im not even happy with this one.
-screwed up my hold passenger bedside by being extremely stupid
Patched in-cab tank hole
new hood
I took my grinder and a wire wheel and zig-zagged all over each and every body panel looking for filler. and boy did i find some on the bed
I found several places of thick bondo. I stripped the filler out to get the area to metal, then hammered and pulled and welded and grinded
I dont have before and after pictures of allll the dents i pulled but heres some.
Here is where the motherload of filler layed. I dont think you can see all the dents though.
After tons of pulling, grinding and hammering i got it straight enough so i wont need more than 1/6in. of filler.
Of course it doesnt always turn out so nice. sometimes it will pull your sheetmetal apart. i had to cut a piece of patch panel out and weld it in.
There was a dent here, this pic is after pulling and before grinding the washers off.
I also welded up tons of holes. I welded up a bunch that were on the top and bottom of the tailgate ( the top ones must of been a tailgate edge protector, and the bottom i have no idea. and no i didnt weld up the drain holes. ). I also welded up a few interior holes on the kick panels, and all the old mirror holes on the doors.
Patch panel came out decent. i still have some grinding to do on the welds.
stripped and prepped for por-15 (corners of firewall, so the wheel well will be all black, not orange)
It looks like i lost some pictures, like the pictures of the door speaker hole patch. hmm.
Next weekends task. THANKS to BigBlueF250 on here for donating this to my project!!!!
sooo i only have a weekends worth of work to do before i am out of things to do due to lack of money for paint. Were going to the junkyard though and im going to gather up all the parts that go for alot on ebay and make some money. I want the whole truck to be in highbuild primer within a month. then i can block it for a month atleast, and have it painted early june. Then back together in July
Thats the plan anyways
