Forest Service Truck Coyote Swap
miller
Re: Forest Service Truck Coyote Swap
Post by miller »
I’m not in a big rush. I just don’t want to bend it back and then have a leak in two years. A little bend I would just straighten out, they should swap it out being it arrived that way. It’s always something!
miller
Post by miller »
Fitted passenger side cab mount, cleaned all holes of epoxy primer and sprayed 3M weld through primer. Installed. The passenger side needed very little modification to be installed.Cab is ready to be flipped back down and start on the cab corners.
hfdco4
Post by hfdco4 »
Very nice work!
:fr: FE390PC
miller
Post by miller »
Thanks Paul. I cut out passenger cab corner. The fit is pretty good, but it seems like the lower flare of the cab corner is not as pronounced as the door so I an going to hang the door back on to make sure those match.The rear rocker area is pretty rusty, but nothing is through and I have to stop somewhere LOL!
miller
Post by miller »
I'll be able to work with that.
Fordkid68
Post by Fordkid68 »
Wow! You're really cruising right along! Pretty soon the rust will be all gone.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
hfdco4
Post by hfdco4 »
Looking good on the passenger side.
:fr: FE390PC
miller
Post by miller »
Sandblasted the inner patch panels for Epoxy primer and found the new panel cracked. Welded up the crack and brushed two coats of epoxy primer. The primer is probably the only thing that will be holding these thin poor quality patch panels together in a few years.
miller
Post by miller »
Installed passenger cab corner. These panels are so thin I had to turn the welder all the way down to 1 to keep from blowing through the metal. This will not be a show truck, but if it was I would have to find something different. It is still a lot of work to do and then to be using crappy parts is a bit bothersome. If they would make them true 18 gauge metal it would be ok, these are 20 gauge thickness for sure.
miller
Post by miller »
The drivers side corner is in better shape so decided to do a lot less of it. I am going to try to do the area in the sharpie.
jimmy828
Post by jimmy828 »
your welds look a whole lot better than mine did. I'm not a very good welder but i a damm good grinder :D Keep up the good work.
miller
Post by miller »
Thanks Jimmy it’s all about how well u can grind it down!
miller
Post by miller »
Passenger side cab corner welds cleaned up.
miller
Post by miller »
Drivers side cab corner. The metal was in much better shape than passenger side.
Fordkid68
Post by Fordkid68 »
Once again, you have done an incredible job!
Is that the last of the rust?
Adam
My first truck,
^^Build Thread^^
