302 with 351 firing order???? why?
BayStYAt
Re: 302 with 351 firing order???? why?
Post by BayStYAt »
Ranchero50 wrote:No, you use a razor blade and cut off the excess. Seat both pieces fully using screwdriver handle and cut them off @ 1/16" above flush (long). Then you rotate them in the groove, I think you want 1/4" sticking out on one side and 1/4" sticking in on the other so the break in the seal doesn't line up with the block to cap separation line. Should be a ton of stuff on Google describing it better.
thanks Ranch, the problem is the steel rod in the center.
BayStYAt
Post by BayStYAt »
Summit is sending a new seal. Felpro said the one I have is incorrect
BayStYAt
Post by BayStYAt »
anyone know where to purchase new head bolts that are NOT ARP? I cant find the stock bolts
BayStYAt
Post by BayStYAt »
pistons in.
Nice!
Ranchero50
Post by Ranchero50 »
Rear sump oil pan? 4x4?
Also note by the amount of corrosion on the head gasket surface that I bet this engine was in a saltwater boat.
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:Rear sump oil pan? 4x4?
rear sump, but not a 4x4
Was it already in the truck like that? Maybe small blocks are different but an FE won’t go in a 2wd truck with a rear sump pan...
BayStYAt
Post by BayStYAt »
yes sir. it was in the truck
Good deal, keep us posted on how it is going,
We love to hear about new engines in trucks! Even better with pictures :D
BayStYAt
Post by BayStYAt »
heads on
Testfit headers but header is touching the block
Also waiting for new timing cover to come in.
2014 subaru crosstrek 0 60
Ranchero50
That's because the 5.0 engines don't have the boss for the clutch pivot point.
I would not run those headers. They are pretty much stock garbage parts and don't flow very well. You should be able to find a pair of used 1 5/8" BBK's for little to nothing. Then just grind the ball flange a little for clearance.
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:That's because the 5.0 engines don't have the boss for the clutch pivot point.
Ranch,
Thanks buddy. I am not looking for more HP. I got these for a cheap price. I am finishing them with POR15 Header paint. I wanted to get rid of the rusty manifolds.
BayStYAt
Post by BayStYAt »
Valve Adjustment?
I read you just run the nut down until tight? Is there a torque setting?
Is there no lash adjustment?
Thanks everyone
Ranchero50
If the studs have positive stop shoulders then yes, lock them down. If the rocker fulcrum will slide down over the shoulder then you need to adjust the lash.
I don't like the rotate the pushrod method because I've seen the lifter plunger lower while doing it. I shake the pushrod axially while tightening the nut. Once the pushrod doesn't move axially (inline with the shaft) then add 1/2-3/4 turn of preload on the lifter plunger.
