1969 Ford Crew Cab / Cummins Project
- HRDROKN
re: 1969 Ford Crew Cab / Cummins Project
Hey MadMaxetc....
Great job on that illustration! Would you mind if I used you post in a couple other forums?
Mark
Mark
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
- HRDROKN
Dana 80 getting disc brakes......
- rjewkes
cool, question on front alignment as far as centering the axles, is the little shackle mount with the hole in it designed to center exactly on the the little nob deal on the springs or is there room for error?
i ask as here in a month or so i'll be changing the worn out u bolts and just want to get it right.
is there a trick to getting it centered? does this apply to both axles on a 4x4?
fuelly.com
fuelly.com
- HRDROKN
The locating pin (spring pack bolt) fits the hole in the top of the spring perch on the axle. Not really any room for adjustment, it generally is what it is.rjewkes wrote:cool, question on front alignment as far as centering the axles, is the little shackle mount with the hole in it designed to center exactly on the the little nob deal on the springs or is there room for error?
- rjewkes
sweet justy get it in there and tighten awesome.
fuelly.com
fuelly.com
- MadMaxetc
Re: re: 1969 Ford Crew Cab / Cummins Project
Go for it.HRDROKN wrote:Hey MadMaxetc....
Mark
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- HRDROKN
Thanks!MadMaxetc wrote:Go for it.HRDROKN wrote:Hey MadMaxetc....
Mark
- HRDROKN
This last week I worked on the power steering mount. Thought about many different ways to skin this cat, but decided that I didn't want bolts sticking through the frame.... so here's the pics. Somehow I had taken more pics during fabrication of all this, but they didn't write to my card... Hmmmmm.
- HRDROKN
Needing a little insight....
Looking on line for brake rotors and it seems that I can find rotors for the 1979 model year, but very little comes up for the 1978 model year So whats the difference and how would I determine exactly what year axle I have? Or does it matter?
Also I noticed that the calipers on the D60 appear to be the same as that D44 HD that I took off the truck.... Hmmmmm.
- averagef250
- HRDROKN
Finally feel like I'm getting somewhere this week.....
Still waiting on all the rebuild parts for the axle... new kingpins, spindles, bearings, u-joints and seals.
- rjewkes
lookin good.
fuelly.com
fuelly.com
- 67mann
The welding looks great nice progress
- HRDROKN
I just sold my old axles as a pair, so time to get that old D60 out of the truck and prepair the D80 to go under. I will be changing the rear springs to 3" wide later down the road....
Out with the Dana 60....
And in with Dana 80..... almost.
- RedneckTexan
