Won't gain friends here with this but this was always one of the main reasons, (and the oil pan gasket) why I was never a fan of the FE series engines Ford produced. The inline 6 also has always had similar issues with keeping exhaust manifold sealed, (it's so...long with so many bolt holes). Wake up that engine, (and forever get rid of the "log manifold" issues by putting some good quality long tube headers on the truck, (I'd plan that if/when the FE gets pulled for a rebuild).
Not for the timid but I've actually had to take a cutting torch and blow out exhaust bolts before like this, (AFTER yanking the carb / getting all gas lines drained in the engine compartment / using fire proofing all over the engine compartment).
That's a lot of work, congrats on moving forward!
Exhaust leak - how urgent to repair?
- basketcase0302
Re: Exhaust leak - how urgent to repair?
- LeoZelig
That sounds like a plan for the future for sure! And I share your frustration with the FE manifold bolts, now that I've struggled with them.basketcase0302 wrote:Wake up that engine, (and forever get rid of the "log manifold" issues by putting some good quality long tube headers on the truck, (I'd plan that if/when the FE gets pulled for a rebuild).
If you'd been here, I'd have let you take a whack at it! I don't have an Oxy-Acetylene rig myself. I've used one back in my appliance repair and HVAC days... which I see you have decades of experience in. If I was still in the business, I'm sure I'd be tapping your knowledge in that, toobasketcase0302 wrote:Not for the timid but I've actually had to take a cutting torch and blow out exhaust bolts before like this
Thanks, it was, and it was worth it. Getting closer...basketcase0302 wrote:That's a lot of work, congrats on moving forward!
Chris
Project Thread: http://fordification.com/forum/viewtopi ... 22&t=96617
1969 F100 - Roy
SWB
3-on-the-floor and I hope to return it to 3-on-the-tree
360
49k on odometer... actual? Anyone's guess
Chris
1969 F100 - Roy
SWB
360
- LeoZelig
Big news, and I won't bury the headline: the manifold is in, and it sounds great!
I couldn't have done it without y'all's advice and encouragement! I can't thank everyone from the thread here by name, but you all played a part in my success.
After cleaning up the head surface, you could see the damage/pitting to the front port. Also, note the heli-coil from someone's previous pain in the past.
The other ports looked a lot better.
I went with the Remflex gasket - they look quite effective and I have high hopes for its longevity and ability to deal with the pitting.
I used all new stainless steel bolts, and Nord-lock washers for the 6 original bolts. For the two through-bolt/nut holes, I went with 5/16" bolts and standard lock washers. Added some high-temp anti-seize to make it easier next time, and torqued all to the Remflex-suggested 25 lb-ft, starting with the middle bolts and working out from there.
A long journey, but worthwhile.
While attaching the exhaust pipe to the flange it became clear all three exhaust hangers had broken. I hung the pipe temporarily until I figure out the next solution...
fastEdsel, that is great advice! I did that on all the holes (well except the ones I drilled out ) and it did make reassembly so much easier - especially on the one with a helicoil. It had been a bear to get that one out, and getting the new bolt in before I ran the tap through made it clear it would be a fight again. Patient work with the tap, and it was a breeze when I did the actual mounting - thanks!fastEdsel wrote:After the bolts are out I run a thread tap through the bolt holes just real gentle to have a smooth re-assembly.
Followed your instructions. As they say, always think about the next guy. Because you ARE the next guy.fastEdsel wrote:Use new bolts, flat washers and lock washers and an anti seize on the bolts because there may be a time when you may have to do this all over again, yup been there, done that!
Chris
1969 F100 - Roy
SWB
360
Chris
1969 F100 - Roy
SWB
360
