Hi,
I just got a 1976 F250 highboy myself and I'm considering the same swap. I have a mustang with a 302 that makes 446 and 467 at the wheels all day long. Have had it for 15 yrs and ran with this numbers on a t5 hard for about 10yrs. My whole point about it, and yes I know trucks are different, weight, etc... but going windsor based would be way easier and less expensive for sure. You can make 500hp easily with inexpensive parts, just put a crank stud girdle for extra insurance. I read an article about a 460 swap which is common but they make it seem like a nightmare for 4x4 f250s.
http://www.blueovaltrucks.com/tech/460_swap.htm
I'm sure the Windsor would be easier, not 100% sure since I just got into trucks but I know the motor will easily make that power. I have a 390fe in mine with a 4 speed and was going to build it, but knowing I can make a 460 small block if I wanted..after market block, or even smaller stroked Windsor with good hp and tq might be the way to go.
If anyone has any input please chime in...as I said I'm new to having a truck, but know Windsors all day long.
Good luck woth your build, keep us updated.
Windsor vs fe vs 460
Re: Windsor vs fe vs 460
1988 Mustang Gt - 302 supercharged 500 reliable hp, track heat heads, blueprinted block, main girdle, edelbrock performer rpm, tubular kframe, stalker nose, etc...
1976 F250 Highboy, longbed, 390fe rebuilt, long tube headers, 35" tires
A crew cab with a small block if going to be a dog, regardless of the HP. Only way I'd consider it is with a pair of smaller turbo's since torque is what moves ya and a 400hp small displacement engine is going to be hurting for torque if N/A.
Personally, a 6bt Cummins will do everything you are asking without the fuss and still give decent economy.
How much does a diesel swap normally cost?
69 f250 single cab (currently), 2wd (currently), 360, c1ae-a heads, streetmaster intake, holley 600, ebay headers, np435, dana 60 with 3.73.
Honestly it depends on your skill set. Doing it your self requires time but not a ton of money. What I've seen from the Cummins swap sites was not impressive. I have a pretty thorough built thread in the projects sub forum.
Now you've really muddied the water... I figured a diesel conversion would be to expensive to consider or it wouldn't be a good value. That's why I never looked into it.
