Short bed CrownVic swap
angryfordrabbit
Re: Short bed CrownVic swap
Post by angryfordrabbit »
so you were able to adapt the c6 mount with the 4r70w trans.
SecondCamperSpecial
Post by SecondCamperSpecial »
angryfordrabbit wrote:so you were able to adapt the c6 mount with the 4r70w trans.
Holes lined up perfect. No modification
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
wbulick76
Post by wbulick76 »
Good info about the C6 mount! What are you planning to run for wiring harness?
1968 F100 SWB project----CV Front----4.6 automatic
SecondCamperSpecial
I am going to pare back the Crown Vic harness.
1967 Cougar project
1988 Bronco 5.8 C6
wbulick76
Post by wbulick76 »
That's my plan too. I have a whole donor car so I can get everything I need.
angryfordrabbit
lol same here.my work schedule changed to 12hrs a day so im a little behind.
SecondCamperSpecial
OK, Crown vic rear axle is installed along with stock crown vic driveshaft. No shock mounts yet.
1967 Cougar project
1988 Bronco 5.8 C6
basshound71
Post by basshound71 »
I'm not positive but I believe you need to box in the frame where you mount the front suspension. Might want to check out some other builds to make sure
1971 Ford F100
2007 Chevy Avalanche
SecondCamperSpecial
Yep
1967 Cougar project
1988 Bronco 5.8 C6
Rocknthehawk
Post by Rocknthehawk »
Is that the stock 2003 rear? Thinking about going that route...pretty easy swap, and I can run a square wheel setup
SecondCamperSpecial
Yep it is the crown rear stripped of 4 link brackets. Stock drive shaft worked also. threw out my back doing rear end as did the trucks owner. So a little time off is needed.
1967 Cougar project
1988 Bronco 5.8 C6
angryfordrabbit
any more updates. im trying to work on mine. i ended up trading my stock 69 for one that has the cv front end done and a tbird irs rearend.
