saved a 66 f100 from the scrapper and swapping frames!
Re: saved a 66 f100 from the scrapper and swapping frames!
I was pissed i couldnt keep my factory steering columb but i figured i wouldnt be able too.. A little blurry but here is the 82 ford steering column.. had to go this route because the slip joint in the shaft was perfect!
I made a 'custom' bracket out of the old gas tank strap.. doubled it for strength
Workin with it......
What a PITA but I got it:D
Since I'm done with it ill say it almost went together too easy..
Without help you find a way to get a second hand ..
A little motivation from hardees...
Out with the old, in with the new, well, 'newer'
Went in like its supposed to be there
Too many projects not enough money!!
64f100 build
http://www.fordification.com/forum/view ... 22&t=72505
64f100 build
- 48prerunner
elgemcdlf wrote:I had thought about possibly just adding to the bedsides & steps. Another thought even though you have it bolted down is to slide the bed forward just a tad. When you do the lift you plan you could move the bed forward a little bit that would help without really making the wheels/tires look out of place in the fenders. I played with the wheelbase on my truck when I did the suspension installs. Longer rides better so I stretched it just a little at each end. Of course the other obvious option is to cut the frame down or just leave it alone. Been there on that trying to measure alone. Totally understand.
might fool the eye if you just moved the stake pocket forward, great project i wanted to do this to my 80 but couldnt find a rust free 66 or older and when scrap price is up aound here you cant touch anthing for less than 5-6 hundred we got $880 for a junk chevy van across the scales.
Cool project I know how fun it is putting those beds on by yourself. Thats why i made a bed lift now.
Thanks for the tip! I fuss about our little rust issues here in alabama until I get on the net and see what alot if folks are dealing with! Rotted off cab mounts and frames breaking in half.. i do have pitty for those states.. 880$!! Man that is alot of money.. Max we see here when high are12$ per 100lbs.. that's why I buy so much out of the scrap yard.. I scored a 51 (chevy ) wrecker a ih tractor and a 48 john Deere tractor and literally, countless perfect motors.. I paid 30$ for the 302 that's going in this truck48prerunner wrote:elgemcdlf wrote:I had thought about possibly just adding to the bedsides & steps. Another thought even though you have it bolted down is to slide the bed forward just a tad. When you do the lift you plan you could move the bed forward a little bit that would help without really making the wheels/tires look out of place in the fenders. I played with the wheelbase on my truck when I did the suspension installs. Longer rides better so I stretched it just a little at each end. Of course the other obvious option is to cut the frame down or just leave it alone. Been there on that trying to measure alone. Totally understand.
64f100 build
64f100 build
A little off topic
Saved this
Don't get mad at me for this one!!:/
Hell, i made my tips out of 100% scrap metal
Saved this
64f100 build
64f100 build
Back on Ol red
Got the bed finished today
Mocking up the buckets
Bolted the tank in too.. good day I'd say
64f100 build
64f100 build
- Alstoyz
MAN O MAN... You are definitely making some progress very quickly!!! Do you ever sleep??? keep up the good work!!!
1970 F-100 SWB Tubbed
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-100 SWB 4X4
- KRob
Very cool M. Dad has a MC Crawler. Gives me a hell of a head ache because i will get it running and then it will sit for a month and not run worth a...yeah.
Anyway good luck with the project very cool.
Rob
Rob
- popeyes71
Cool project! Keep us posted! I like your future projects as well.
-Popeye-
1971 F-250 4x4 Highboy
Lol! I guess these old fords are my cocain, I'm addicted and can't get enough! I actually started this project a week ago I'm just bringing things up to speed here.. bolting the tank in is where Im at now.. .. Sleeping? No!! I'm up at 5 some mornings and going down at 2 AM!Alstoyz wrote:MAN O MAN... You are definitely making some progress very quickly!!! Do you ever sleep??? keep up the good work!!!
That's neat, I know the jd is gonna be temperamental if I ever get it running.KRob wrote:Very cool M. Dad has a MC Crawler. Gives me a hell of a head ache because i will get it running and then it will sit for a month and not run worth a...yeah.
Anyway good luck with the project very cool. Rob
Thanks bud, hopefully the truck will be rollin soon!
Thank you! I take pictures like a pissed off 16 year old girl texting .. ill keep ya informed!popeyes71 wrote:Cool project! Keep us posted! I like your future projects as well.
64f100 build
64f100 build
- KRob
Those JDs are pretty simple as long as the engine is semi sold you can make it run. Look at re working it to a 12v system before you start buying parts. I wish i had realized you could do that before the last time i went through the ignition system. There is a pretty good forum http://www.jdcrawlers.com/messageboard/ ... c2b6445bcf, its about crawlers but the engine will be the same as the MC.
Anyway, good luck
Anyway, good luck
Cool! Iv been wondering if there were a site like that for the old Deere . After looking for the past 3 years i finally found a complete 12v electrical kitKRob wrote:Those JDs are pretty simple as long as the engine is semi sold you can make it run. Look at re working it to a 12v system before you start buying parts. I wish i had realized you could do that before the last time i went through the ignition system. There is a pretty good forum http://www.jdcrawlers.com/messageboard/ ... c2b6445bcf, its about crawlers but the engine will be the same as the MC.
Anyway, good luck
64f100 build
64f100 build
Okay, today's project is gonna be getting the brake pedal where it needs to be.. in the picture its obviously too high but the fix is easy. I ran into this putting boosted brakes in my dads 79 and had good luck with it.. ill show how I accomplish this shortly..
Here is his baby
Here is his baby
64f100 build
64f100 build
Okay, here is how I shortened the push rod for the break booster
Good as new
Looks about as good as its gonna get by my hands
Scratched the buckets because they put me in the roof of the truck but buckwheats old bench will look good with my baby beside me!
I peeled the cracked dash cover off to find a beautiful dash!
Good as new
64f100 build
64f100 build
Clutch kits on the way! Ill be rollin soon..
64f100 build
64f100 build
Okay guys, photo bucket locked my pictures They will be back up in 10 days.. sorry
64f100 build
64f100 build
