'71 CREWCAB SHORTBED DUALLY
jdeshler
Re: '71 CREWCAB SHORTBED DUALLY
Post by jdeshler »
Yes I love it!! That's gonna be a nice one when you're finished :thup:
Too many projects not enough money!!
64f100 build
http://www.fordification.com/forum/view ... 22&t=72505
Alstoyz
Post by Alstoyz »
Well. I finally got some parts & time to play with the crew this weekend!!! :woohoo:
1970 F-100 SWB Tubbed
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
Alstoyz
Post by Alstoyz »
It was a long weekend. Did I mention HOTT!?!? :lol: got all the old drum brakes and F250 springs out!!! :woohoo:
1972 F-100 SWB 4X4
Alstoyz
Post by Alstoyz »
Going back in with new rotors, calipers, polyurethane bushings, brake lines, master cylinder, and shocks...
1972 F-100 SWB 4X4
guhfluh
Post by guhfluh »
Truck looks good!
That brake line looks too tight though. I'd worry about turning and bumps/full extension at the same time.
What are your plans for the rear wheel well?
It also looks like the front lifted some. Is that because of F250 spring pockets and F350 springs?
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
Alstoyz
Post by Alstoyz »
In the pic the suspension is fully extended. "The shock is maxed out" turned it from lock to lock and the line was never in a bind. I was worried myself... I did have to cut the little tail from the spring due to the spring bucket differences and left it a little long. My plans are to remove the I-6 and 3speed from the PO this winter and install a 460 EFI/E4OD.?. At that point, if it doesn't settle down some more I will trim some more off of the spring. As for the fenders, I'm going to make some custom fenders...
1972 F-100 SWB 4X4
Alstoyz
Post by Alstoyz »
Well, I haven't got to do much with the crew here lately. I've had a career change which means a lot less time to play... However I did get to play a little over the holidays. :woohoo: Not much to report, but some progress. Got the 40/20/40 from a '97 F-250 installed, and some newer styled mirrors mounted on the doors... Will try to post some pics later. Having some issues.?.?
1972 F-100 SWB 4X4
Fordnatic
Post by Fordnatic »
Nice project!
55F100
Alstoyz
Post by Alstoyz »
Fordnatic wrote:Nice project!
Thank you... :D
1972 F-100 SWB 4X4
SATURN5
Post by SATURN5 »
Nice...... I wish I had the space for a crew.
Have you thought of using flareside fenders?
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
Alstoyz
Post by Alstoyz »
Thank ya sir... i've kicked around a few different ideas. Flares were one of them. But I've rounded up 2 pair of front fenders from a F500/600, I will cut from the middle back portion of each fenders and splice the left rear to the right rear and create one fender... It will require some metal massaging but I think it will look factory ish... :D
1972 F-100 SWB 4X4
chad67
Post by chad67 »
Everytime I see the members on here from the south, I get a sting of jealousy. I have scoured 3 junkyards and was only able to find a door, driver's inner fender,and a relatively rust free cab that wasn't beyond repair. Two of the yards I scoured were in northern Arkansas, that's where I found the cab and fender. It looks like you have a clean build going on. I love bump crew cabs and it looks like you got a nice one.
1967 F100 SWB
1991 Thunderbird 5.0 with fully ported gt40 heads, cobra intake (also ported) and a trickflow stage 2 cam, manual steering, and custom 3" exhaust
Alstoyz
Post by Alstoyz »
Thank you sir. I actually have 2 bump crews. I have a 72 F-350 crew. I've had it for almost 20 years now. I'm putting it on a 93 F-350 4x4 chassis. It's quite a project... I've been trying 2 post pics lately but it keeps telling me my file is to big. I'll see what I can do. Do you have plans to attend Fred Nelson's show this year???
1972 F-100 SWB 4X4
chad67
Post by chad67 »
I don't know. When will it be this year? Isn't it close to Springfield, MO?
1967 F100 SWB
Alstoyz
Post by Alstoyz »
It'll be June 14th. It's in Anderson, Mo. I think that's close to Springfield.?.?
1972 F-100 SWB 4X4
