c6 adjustment?
Re: c6 adjustment?
Another small tip on the vacuum hose: full manifold vac is needed, also create a loop in the vac. line to reach higher than the carb..This will keep fuel out of your mod. valve if your engine should sneeze..Later vehicles ran the vac. to a tree on the firewall for this reason..Donnie
