Why won't it go back on?
- zoomer
Re: Why won't it go back on?
It's a standard long bed with a 3 speed manual transmission.
1971 Ford F100 Sport
302 3 on the tree
Revelation 12:11
And they overcame him by the blood of the Lamb, and by the word of their testimony; and they loved not their lives unto the death.
By this I am a Monster to the Monster!!
i should have both the front and rear half for that transmission. i am guessing you only want the front half.
- zoomer
I'll let you know later today. I'm gonna get out there and work on it once it warms up some.fordman wrote:i should have both the front and rear half for that transmission. i am guessing you only want the front half.
302 3 on the tree
Revelation 12:11
- zoomer
Well today I took a small file and cleaned up the splines on both shafts, I was able to knock it on with rubber mallet. I can tell a difference, but I still have a roar... I'm hoping it not the axle bearings or a the pinion bearing.
302 3 on the tree
Revelation 12:11
if you had to beat it on with a hammer it might be binding-to tight.it should have a little movement.
- zoomer
Not full swings... just a little help from the mallet, Not a lot of leverage laying on my back on a creeper.71highboy wrote:if you had to beat it on with a hammer it might be binding-to tight.it should have a little movement.
302 3 on the tree
Revelation 12:11
- Mancar1
Hope you got it right. Shouldn't have to use a hammer, even a rubber mallet. Of course in the ship's engineering space when someone was having a problem repairing a piece of equipment we used to say. "Get a bigger hammer."
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- zoomer
I drove it to work today... It is doing fine, I just gotta figure out where the roar is coming from. I really had hoped it was the carrier bearing.
302 3 on the tree
Revelation 12:11
when did this roar appear? all of the sudden or has it been growing. have you puy new tires on lately? how is the fluid level in the rear end? have yo utried changing the fluid? cluthc fans can make a roaring sound too.
- zoomer
It must have been gradual, I didn't really notice it until my wife asked me what was that noise.. My hearing isn't so keen anyway.fordman wrote:when did this roar appear? all of the sudden or has it been growing. have you puy new tires on lately? how is the fluid level in the rear end? have yo utried changing the fluid? cluthc fans can make a roaring sound too.
I had just put new tires on it before then, BF G. T/As They aren't loud tires.
I checked the oil Sat, it held about a cup maybe. the trans held about the same. No clutch fan on this motor.
302 3 on the tree
Revelation 12:11
- BobbyFord
Axle or wheel bearing.
- Mancar1
Same tires I recently put on, you are right it wouldn't be them. Mine are not noisy. I agree with Bobby, sounds like it is a bearing.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- zoomer
Well, we found the culprit of the roaring... There was about a eight of an inch play in the left rear wheel, so that axle bearing was replaced.... took it out and roadtested it... Still Roaring!! So we jacked it up, put it in high gear and let it run... noise coming from the right side. No play what so ever in this one. Pulled the axle and the bearing was tight! Really tight and rough. Replaced that bearing and now all is quiet.
302 3 on the tree
Revelation 12:11
- BobbyFord
Axle bearings do not need to have play in them for them to be noisy or bad.
- mlheppl
