shifter lever bowl broken
umpalumpa1985
Re: shifter lever bowl broken
Post by umpalumpa1985 »
You guys are awesome. Thanks once again to the wonderful Fordification community for always being willing to lend a helpful hand.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
~ Rami Belson
cdeal28078
Post by cdeal28078 »
IF you have a camera take a few pictures as you go. Never can hurt. It is not bad though like said. A lot easier then a manual.
As long as you have a F100 you always have a work bench
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Mancar1
Post by Mancar1 »
I know how that TAD routine goes. Sounds like you have already received all the tech. assist you need. Let us know how it goes shipmate. Full sails and following winds. CPO Ret.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
umpalumpa1985
Sorry it's been a while. Got busy. Anyway, the fix was much easier than I thought. I did it all in the truck, and I can honestly say that I did it in the time it would have taken me just to get the column out. I just calmed down and looked at it, and. . .**** only goes together one way. Ha ha ha. Imagine that. In any case, thanks for the help/tips/advice. And thanks to the old guy with the cattle farm that let me pull the shift tube out of his unloved, abandoned rust bucket of a bumpside. :fr:
and Semper Fi, Chief! --Sgt C
~ Rami Belson
