My 69 F100 Ranger
TX69F100
Re: My 69 F100 Ranger
Post by TX69F100 »
jnash40 wrote:just curious what headers did you use , and did you have to cut the frame for them to fit, i have a 302 and i heard there are problems putting the headers in??
I believe these are the exact headers that I got:
http://www.summitracing.com/parts/HED-89106/
No cutting of the frame was required for clearance.
Brent
1969 F100 Ranger 390/C6 <--- Build thread
72stepside
Post by 72stepside »
(drooling all over the place)
I hate you!
Nah really, very nice!
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
BobbyFord
Post by BobbyFord »
The selector shaft is held on by a nut from the inside. Pan has to be removed, valve body removed by removing the 8, 3/8" headed bolts, small nut removed on the outside from the kickdown lever and then large nut (requires 7/8" wrench, I believe) removed from the inside linkage.
You can see the nut on the inside of the linkage in this picture:
BobbyFord
Post by BobbyFord »
BobbyFord
Post by BobbyFord »
Incidentally, I noticed in the pics that you and your wife have open-toed/flip-plop shoes on out in the garage :nono:
Just a little advice; a toasted foot takes a long time to heal. Even something as simple as a dropped wrench could result in some serious foot pain.
When I was a kid at my dad's shop I had flimsy shoes on and, while stepping over an engine block, clipped a corner on the block just in the right spot on my foot to hit a nerve. To this day, if I hit that spot again, it makes my entire foot feel cold as ice. Protect your feet, they're the only set you're gonna get :thup:
TX69F100
Post by TX69F100 »
BobbyFord wrote:The selector shaft is held on by a nut from the inside. Pan has to be removed, valve body removed by removing the 8, 3/8" headed bolts, small nut removed on the outside from the kickdown lever and then large nut (requires 7/8" wrench, I believe) removed from the inside linkage.
Thanks for the info!
Brent
TX69F100
Post by TX69F100 »
BobbyFord wrote:Incidentally, I noticed in the pics that you and your wife have open-toed/flip-plop shoes on out in the garage :nono:
I agree, and that's why I'm not wearing them. The wife was sure to steer clear of any danger, and only came outside to bring water and snap photos from time to time. Matt assured me that his were steel-toed flip flops. :hmm:
Thanks for the tip.
Brent
TX69F100
Post by TX69F100 »
The 390 lives!
http://www.youtube.com/watch?v=5hTpju8-n9U[/video]
The headers are leaking a bit, so there's an annoying tick, and Matt still has some tuning to do on the carb. It's great to finally hear it run, tho!
Brent
TX69F100
Post by TX69F100 »
here's a better start-up video in the daylight:
http://www.youtube.com/watch?v=Wv_zuOg3-jQ[/video]
Brent
jnash40
Post by jnash40 »
very nice finally got my welder shipped to me so now i can finish my bump YES
67 ford f100s rule
Post by 67 ford f100s rule »
listen to that 390 rumble. You gotta love an fe. I hope to find one for my 70 eventually
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
TX69F100
Post by TX69F100 »
jnash40 wrote:very nice finally got my welder shipped to me so now i can finish my bump YES
Thanks! That's exciting. I look forward to seeing your progress.
67 ford f100s rule wrote:listen to that 390 rumble. You gotta love an fe. I hope to find one for my 70 eventually
Yes sir! What are you looking for, specifically?
Brent
TX69F100
Post by TX69F100 »
Finally got her home and cleaned up a bit:
New video:
http://www.youtube.com/watch?v=MMFr9luBzuI[/video]
Brent
sport71
Post by sport71 »
Looks great!!!
Those who do not learn the lessons of history, are doomed to repeat it.
jp2005
Post by jp2005 »
Good job on the install! what did you do with your 360?
