More done on the 72'...
zakt
Re: More done on the 72'...
Post by zakt »
yes that will be the motor, that is the old motor out of my 95 F350 (EFI 460). Have some custom headers for it that should fit inside the frame so have to see how that all goes :thup:
1972 Ford F350 crewcab
zakt
Post by zakt »
got the fan shroud finally all done and in the process of getting it made (16gauge stainless steel) Have the (2) 12" spal pull fans also with 185 degree sensor. Will post a pic of it when I get it attached to the radiator also.
zakt
Post by zakt »
Custom stainless steel fan shroud done for the stock super cool radiator with 2) 12" spal pull fans
basketcase0302
Post by basketcase0302 »
Very nice work Todd! :thup:
SoCalExile
Post by SoCalExile »
Nice work! when you get it in can you post how you have it set up electrically?
zakt
Post by zakt »
I will be using the Spal 185FH
185 DEGREE THERMOSTAT 185FH
Description of SPAL ADVANCED TECHNOLOGIES 185FH
Each kit contains:
-Fan relay harness (FRH)
- Fan pigtail (FR-PT)
- Fuse holder
- 185TS
- 3/8" to 1/2" thread adapter
- 30 Amp fuse
- Yellow butt connector
- Yellow ring connector
- Blue ring connector
BigBlueF250
Post by BigBlueF250 »
Any progress to report Todd?? Any frame progress pics?
rjewkes
Post by rjewkes »
where does the sensor go? ion the stock temp sending unit hole or the does it attatch to the rad?
fuelly.com
FormerMarine1981
Post by FormerMarine1981 »
Nice truck, I wish mine was a long bed. I would like a 4x4 too but since I live in the city there is no NEED for one.
zakt
Post by zakt »
picked up a 06 F350, V10 so now the truck frame is outside and the garage is maxed out. Decided to do the bed and the cab next to free up some space. Couldnt bring myself to keep the 06 F350 outside :D
BigBlueF250
Is that a Che Che Chevy in your garage!!!!!!!!???????????????
zakt
Post by zakt »
That it is had that suburban since new in 99' K2500 4x4 (454CID) but I also have the 06 F350, 72 F350, 69 F250 (pieces parts) and 68 F250 (pieces part) :D
zakt
Post by zakt »
started on the truck bed, cutting out the damage (driver side)
(passenger side, NEXT)
zakt
Post by zakt »
decided to cut out the aux fuel hole alittle better to patch and plug weld to the braces....also notice in the top picture the front brace is off can just see the spot welds I need to grind down alittle to put the new one on.
before:
after (just need alittle more trimin):
zakt
Post by zakt »
picked up a sand blaster
