'67 F100 stepside - full resto new photos 03/03/2013
- 67nukeford
Re: '67 F100 stepside - full resto project storyboard
Looking good so far! I did the same, with the baggies and index cards. I also have a bunch of boxes for each are where the parts are from.
- 69F110
Looking good!
Steve Davis
Pastor and U.S. Army Retired
- tybob81
Remember to take lots of pics during the tear down so when it is time to put it all together you don't have to second guess yourself. I did and wish I would have posted it on photobucket too, because Wal mart lost my photos the developed!!
- 67mann
Doing a little target practice while working on the truck looks like a good sized caliber---can't wait to get to my next place so I don't have to pack everything into the truck to go shoot
Moving right along on your progress---Are you going to strip down the frame and rust treat it
- stephen44
- thats an old hood i got for some welding practice - came with free holes !67mann wrote:Doing a little target practice while working on the truck looks like a good sized caliber---can't wait to get to my next place so I don't have to pack everything into the truck to go shoot
and yes I am taking the frame all the way down and sand blasting it etc
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
- stephen44
so - it must seem like I have disappeared but I have slowly been rebuilding teh rust
here to remind you was what i started with
thanks
Stephen
Stephen
- stephen44
and here is where I am at..
thanks
Stephen
Stephen
- 72stepside
Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Hedman Headers
Disc Brakes
- 69FLATBED
Dang Stephen, that was a fast teardown! keep up the good work.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
- stephen44
good - thank goodness for that72stepside wrote:Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
- Stephen
thanks
Stephen
Stephen
- stephen44
69FLATBED wrote:Dang Stephen, that was a fast teardown! keep up the good work.
thanks - as I am finding out - the tear down is the easy bit
- Stephen
I got guns - paint & filler delivered today - so I can see light at the end of the tunnel
-(as the old joke goes - let's hope it isn't a train )
thanks
Stephen
Stephen
- stephen44
Re: '67 F100 stepside - cab corner replacement - pics
I thought I'd document how I did this - as you cannot buy the inner corners - and this might help someone as I could find no hints on the best way of doing this. Now remember - I have no metal working experience - so i am not saying this is the right/best way of doing this - but this seems to have worked for me.
this is what i started with (other side)
i decided to butt weld - as i knew i could get to both sides - I took the cut too the point of good metal and since the replacement part did not fit exactly - just shy of the mold line.
thanks
Stephen
Stephen
- stephen44
I then welded and ground both side
I made the inner corners from the left over outer corner - I flattened it with the BFH
- for the beading on the original inner corner - i cut back to good metal and then slit the beads and flattened to give me an edge to butt weld.
I epoxied all the insides to give them some protection before welding on the inner corner.
I shaped the edges over a wooden table and a stone paver
thanks
Stephen
Stephen
- stephen44
I continued shaping till I was happy with the fit and then welded up
I kept on welding until all pin holes had been sealed and then ground down
thanks
Stephen
Stephen
- stephen44
Re: '67 F100 stepside -cab corner replacement - pics
I also started sanding the cab down
thanks
Stephen
Stephen
