a little guy with a big hammer moved into my engine
Re: a little guy with a big hammer moved into my engine
if you have an fe engine you will need a 6 cyl bellhousing or a 6 cyl transmission to put the 240 in place of a fe.
67_p_car
Post by 67_p_car »
more info please? how do i determine if I have an fe - I mean I know it is made of iron - but i don't think that's what you mean
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
St. Paul — Zumbro Falls, Minnesota
an fe engine is a (in our years of trucks) is a 352 360 and some trucks had 390 engines inthem. if the engine is origianl then the door data plate would be able to say what the engine was. since i see you have a 68 f100 it is probably a 360 but could be anything else. a fe engine has 5 bolts in each valve cover. http://www.fordification.com/engineID.htm
67_p_car
Post by 67_p_car »
the truck currently has a straight 6 in it.
1966 Beacon
1968 Ford F100
1967 Porsche 912
2002 VW Jetta TDI
ok then you wont have any problems at all. i didnt see that in your post i guess. no need to woory about the transmission then.
