got my new headers on tonight!! PICS (updated 5/27)
marvin2
Re: got my new headers on tonight!! PICS (updated 5/27)
Post by marvin2 »
Awesome job man!
This is the exact setup I want to run on my truck when it comes time for my exhaust work. Anyway you could post up a soundclip or video? Where did you pick up the headers...summit?
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
green1970
Post by green1970 »
yeah, i got them from summit. the part number is HED-89150. i had to lift up the motor and take the right side engine perch off the slide the right header in. But it is worth it!! i will try and get a sound clip of it up here before i leave for Guatemala. But if i cant, i will when i get back!
tyler
Happy_Camper
Post by Happy_Camper »
Very clean work! Looks great. I agree on the "H" pipe. Really helps balance the tone.
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
marvin2
Post by marvin2 »
Thanks for the part number 70...I just added it to my summit wish list!
68monster
Post by 68monster »
hey is that a air horn that plays dixie? ha ha ha i have the same horn! good to see that i'm not the only one!
1967,1968,1970 4x4 ranger!
Johnm
Post by Johnm »
you exhaust man did a great job! i have had my exhaust done a few (4) times now and i have never got a job that good.
green1970
Post by green1970 »
he did a great job!! he only used a oxycetelyn torch and a rod to weld to!! This is the first time i have used this guy, but im going to stick with his shop!! thanks for all the comments guys!
tyler
green1970
Post by green1970 »
tyler
71 LONG BED
Post by 71 LONG BED »
Nice work!! Everyone warned me about the headers cooking my starter and I didn't believe them. I only drive the truck 1000-2000 miles a year so it took a little longer than they said, but it is starting to show signs that it is on it's way out. half the time I turn the key it just spins with out engaging into the flywheel. It usually works on the second try. I just wanted to let you know so your not surprised when it happens. :thup:
John Member #1549
Image Image Image
green1970
Post by green1970 »
thanks for the tip!! i have not been on here in awhile. I just got back home from my mission trip in Guatemala! had an AMAZING TIME! i hope it doesnt cook the starter, but my uncle has a 68 truck with a 390 with headers and they have been on there for about 15 years and it hasnt cooked the starter yet, so knock on wood my starter wont get cooked. I guess i could invest in some heat wrap and put it around the starter.
tyler
lee_ford
Post by lee_ford »
71 LONG BED wrote:...Everyone warned me about the headers cooking my starter and I didn't believe them... ...half the time I turn the key it just spins with out engaging into the flywheel.
Since it spins then the wires are not cooked. Sounds like you may have cooked all the lube out of the pivot for the lever that pushes the bendex into the flywheel and/or the main starter shaft at that point. Pull it apart and use graphite on it. Should fix it. We used graphite inside large bread ovens, so it should hold up to a header close by.
Warning: DO NOT OVER DO IT and DO NOT GET GRAPHITE ON or NEAR THE BRUSHES!!! It WILL conduct electricty.
My 1969 F100 Gallery
