white smoke from crankcase?
Re: white smoke from crankcase?
the paint on the bottom spring cup and push rods show why you should put the valve cover on before painting the engine and the valve cover bolts.
hotrod ford
Post by hotrod ford »
i have posted more info and pics on the project forum. so far i'm lead to believe the problem was a bad gasket.
1971 Sport Custom SWB: 360/C6 3.00
1965 Ford Falcon 4Dr: Inline 170 3sp
chirrin
Post by chirrin »
so guys i have a question with all this , before i started to use the car again it was sitting in the yard for 8 months do u think probably the valve guides got dry and they r not working properly?
and when i changed the water pump i grab the house and stick it into one of the holes of the water passage besides having rust and mineral build up a dark chokolate like color on the water start to come out and i kept the hose in for a while and kept comming out. next thing i did i drain the oil out of the engine to check for signs of water on the oil but i didnt see any.
is that normal or i got something going on?
