1988 efi pcv hose routing pics
Re: 1988 efi pcv hose routing pics
heres a pic off the last three ports that i need to find out about if anyone knows or if you have any pics of your engine. thanks for your help. the one on the right is to the throttle body. the other two are on the vacuum te on the top intake. you can see the bolts in the hoses. this is all thats left. i got the canister to the throttle body hooked up a while ago.
averagef250
Post by averagef250 »
All the ones circled are capped off. Actually, the two ports on the throttle body are supposed to be tee'd together into one. Not sure why, but that's how the factory did them.
