1971 f250 DESERT truck- 10/24 race prep
1971ford
Re: re: 1971 f250 DESERT truck- father/son build. update 7/3
Post by 1971ford »
Mooosman wrote:http://www.pirate4x4.com/forum/showthread.php?t=602287
Check out this thread on Pirate4x4.com It's an F-100, but the same things apply. I think the leaf spring suspension will work fine for you. That F-100 in the thread uses Deavers (I think) shackles and springs for more travel.
He also welded on extra shock mounts on the front and rear. It would be a good idea on yours, too.
Nick :thup:
ive been watching that thread closely, you can see that ive "bumped" it up to the top quite a few times looking for updates :D . cool build, im lovin it. he just needs to work faster.
i think ill use Deavers too, i just got to get a good enough shock to go above the leaf packs.
Mooosman wrote:Cool truck! I wanted to make my 72 F-100 into a vintage style desert truck, but it's all original and too nice to cut up...
thats EXACTLY what i said a couple months ago... and here i am :eek:
-Ryan
RedneckTexan
Post by RedneckTexan »
Keep the pics coming Ryan! :D
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
1971ford
Post by 1971ford »
cage ideas:
give me your input :)
the brown is just to try to make the design easier to see. to avoid allusions.
the green bar is under the bed.
with fuel cell: also im thinking i might "countersink" the fuell cell into the bed like the 2nd pic
OR
(pretend the green bar isnt there and the black bars go underneat the cell with a skid plate protecting it)
squint and it looks better. this is following OFF-ROAD magazines bumper build design.
what would you do differently ?
thanks
-Ryan
Ranchero50
Post by Ranchero50 »
I'd mount the tires up closer to the cab to bring their weight closer to the center of gravity. But then again, I guess it depends on the weight bias since it seems you'd want it a little tail heavy. The 429 is going to hurt you for weight bias.
I like the idea of getting rid of the 250 suspension to eliminate some unsprung weight as well.
Gonna be an interesting project.
Jamie
1971ford
Post by 1971ford »
Ranchero50 wrote:I'd mount the tires up closer to the cab to bring their weight closer to the center of gravity. But then again, I guess it depends on the weight bias since it seems you'd want it a little tail heavy. The 429 is going to hurt you for weight bias.
Jamie
yup yup and yup.
with the 429 big block, much weight in the back will be needed and much aluminum will be needed in front to prevent endo-ing over. have to try to balance it out.
the f250 suspension is history. or WILL be.
the leafs will definately be replaced with Deaver leaf packs (offroad leaf spring company, they make VERY nice springs) and some type of shock will be mounted on top of the leaf packs. not sure if it will be just two resevoir shocks per wheel, or a double bypass but we shall see.
for front suspension i'd like to keep the f250 i beams. the BRODOZER(67 offroad truck, really cool build) was playing around and they bent a f100 i beam enough so it was undrive-able. that was just testing. so f250 beams should be good.
also i want to put some KING coil overs in front. extended radius arms as well
yes, it will be VERY interesting :)
-Ryan
1971ford
Post by 1971ford »
havent done too much lately.
but need some input.
my dad and i have talked about cutting out the dash and replacing it with a simple aluminum dash. with guages etc.
that would save quit ea bit of weight.
but im also thinking it would be really cool to use the stock dash. but thats quite a bit more weight. but since we wont need a am/fm radio and heater/ac controls, what if we put a sheet over those holes and install 4 guages (oil pressure, temperature, fuel and water for example) for the co-driver to monitor, and cut the center of the cluster out and replaced it with a sheet of aluminum with the speedo and tach for example.
maybe weld a sheet over the glovebox hole for more guages even.
what do you guys think? im thinking your all going to say keep the stock dash, so i wouldnt be hacking up a bump though :D
-Ryan
FordTruck
re: 1971 f250 DESERT truck- cage ideas
Post by FordTruck »
With the cage i would go with the third drawing,and they dash i would either go with the aluminum one or have is shaped to resemble the stock dash but that's just my :2cents:
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
layedout72
Post by layedout72 »
Why do you say a 4 link is expensive? You work at a welding shop, that's where the money goes. By some 2x2x3/16 wall, some 3 inch long 2inch round DOM bar ends and get to work!
You MIGHT have 100 dollars in it when it's said and done.
Coilovers you can buy from any truck that would work, and make mounts to make the travel like you want.
1971ford
Post by 1971ford »
finally spent a day working on this truck instead of the 69 f100.
this is what did
removed the radio, wiring, glovebox/door, heater/ac (alot of weight saved there!), heater/ac controls, the seat, the carpet, the sound deadener, the reamains of the firewall cover, and the dual tank switch and wiring, and the lower valance, and i mounted the liscense plates so its streetable for now
replacing this heavy bench with racing buckets will be a big weight saver as well
plans are to rhino-line the floor later on, and cut out the front of the dash from the radio/heater controls on to the glovebox area and put a sheet of aluminum there and install the guages for co-driver. then cut out the whole center area of the cluster, and install the street driving needed guages.
-Ryan
19674x4
Post by 19674x4 »
i like the idea of mounting the vital guages for the co-piloit to monitor, but the co-pilot is usually your navigator, so hes always watchin a map and reading you directions over the radio, might i suggest mounting them in the center with warning lights below each one, for hi-temps, low pressure, ect. and have the tach and speedo in the stock cluster location.
My Photo Album
1971ford
Post by 1971ford »
19674x4 wrote:i like the idea of mounting the vital guages for the co-piloit to monitor, but the co-pilot is usually your navigator, so hes always watchin a map and reading you directions over the radio, might i suggest mounting them in the center with warning lights below each one, for hi-temps, low pressure, ect. and have the tach and speedo in the stock cluster location.
well i didnt really mention that we will also be fabbing a big center section that stretches from the bottom of the mid dash down to the floor for a portion of the guages plus the art-carr shifter. so i dont think we will have any guages over the glovebox area, since i will save that for in the far futer so our GPS can go there.
since we will just be doing 300 mile races, in laps of 6 or so, we wont be using GPS. we may have a paper map of the general turns and such. but were going to have to rely on sight.
co-driver should have a good amount of time to scan the guages
-Ryan
71PA_Highboy
Post by 71PA_Highboy »
Rhino is HEAVY. If you are trying to reduce the weight, and since it will be a desert racer, rust shouldn't be an issue.
POR15 and a topcoat would be sufficient... and much lighter.
jmho,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1971ford
Post by 1971ford »
yeah i thought it might be heavy. i think we'll just leave it as it is or lay down some thin carpet
-Ryan
James72
Post by James72 »
lookin good man :thup:
oh, and you should send that AC unit my way :D
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
1971ford
Post by 1971ford »
the a/c unit will be up for sale soon :thup:
-Ryan
