Got some work done, and photos will be coming soon, but to check off the list, I installed the new maual steering gear box on the frame, got the flywheel ground. installed the flywheel as well as the clutch, pressure plate, and throw out bearing, and followed up with installing the transmission last night.......getting there!
2017 Ford Raptor
1975 Ford Bronco
"WARNING! Being Hit with The "Brick Of Life", is just a hint that you are about to be run over by the "Boulder Of Being"!"
1967 F-100 Base Long bed. 390 4Bbl, NP435 4Spd, Manual Steering, Manual Brakes, A/C. (BlueBeast).FOR SALE-NOT!
1967 F-350 C&C, 159"WB.(Donor Truck)
1967 Mercury Cougar Standard. 5.0 HO, RUG-E 4 Speed, Factory Triple Black, Console Car.(SOLD)
Still need to get away from work for more than 10 hrs, but got the pitman arm cleaned and painted in prep for installation, as well as ordering a new drag link. Also tore down the intermediate shaft on the bottom end to figure out what I need to overhaul it.
2017 Ford Raptor
1975 Ford Bronco
