parting out 67-72 2wd trucks (new list of parts) 12/10/11
Re: parting out 67-72 2wd trucks (new list of parts) 12/10/11
sorry if its been asked but do you have a short bed drive shaft?
- rmurphy
only have one, it's rusted out. sorrywblcrz wrote:do you still have the 8 ft bed and if so how much?
- rmurphy
sold or using it.turner-f100 wrote:sorry if its been asked but do you have a short bed drive shaft?
Hi Looking for a 2 piece driveshaft for a 1968 F100 Longbox FE c6 auto unit; Driveshaft is the type that bolts onto flange on transmission output yoke.
thanks
thanks
Kelly
- rmurphy
I have that shaft. Do you need just the front $50 or all $100. and shippingkiroboy wrote:Hi Looking for a 2 piece driveshaft for a 1968 F100 Longbox FE c6 auto unit; Driveshaft is the type that bolts onto flange on transmission output yoke.
thanks
Dear RMurphy: Looking for the bracket that holds/supports the 2 brake lines descending from the 2-chamber Master cylinder to the proportioning valve on the frame.
I believe it sits on the steering gear box and has part # C7 or 8TZ-2A275-?
I am re-doing a '66 F250, but converting the brake line system to a '67 to get the dual M/cylinder.
Any chance you have that bracket?
Thx. Jeff(lovesf250s)
- rmurphy
got that bracket manual or p/s. got both $10 and shipping.jefflovesf250s wrote:Dear RMurphy: Looking for the bracket that holds/supports the 2 brake lines descending from the 2-chamber Master cylinder to the proportioning valve on the frame.
Thx Rmurphy. Any possibility of pics? Jeff
RMurphy: Interested in both brackets. My truck came with manual steering, but I have a power steering box, and if able to locate P/S pitman arm, plan to convert as I re-assemble my F250. Thx for pics. Jeff
- rmurphy
got a couple p/s boxes. I can pull off a pitman arm. Is a f100 the same?jefflovesf250s wrote:RMurphy: Interested in both brackets. My truck came with manual steering, but I have a power steering box, and if able to locate P/S pitman arm, plan to convert as I re-assemble my F250. Thx for pics. Jeff
(1) manual box bracket (2) p/s bracket price $10 ea, pitman $25
Rmurphy: Thanks for the pics & offer of Pitman arm.
I'll send you an e-mail to discuss further
Rmurphy: Did you get my e-mail? Jefflovesf250s
- rmurphy
- guhfluh
Ronnie, do you have any good steel headlight bezels without pits or dents?
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
- rmurphy
